small head #'S...
Old Nov 4, 2005 | 03:50 PM
fordraceboy's Avatar
fordraceboy
Question small head #'S...
does anyone know what the casting numbers are for the heads that had real small ports?
Old Nov 4, 2005 | 06:43 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Most late 66 and later heads have the smaller medium riser posts. A few exceptions are the CJ heads which have lowriser style ports and some 427 castings. As far as casting numbers go there are lots. Anything in paticular your looking for? And you do mean ports not chambers?
G.
Old Nov 5, 2005 | 12:14 PM
fordraceboy
i'm not sure what i'm looking for, just had a thought.. it is the small ports i want, though i've heard that alot of those style heads had the small chambers also.. I want to see how the exhaust port is cast right where it exits into the header.. if it has the standard size lip there or hopefully no lip at all...
Old Nov 5, 2005 | 03:38 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
D2's, C4's,C6's,C3's,C2's all have the larger runner,and with Some light porting will really start to come alive!! and with max effort Port work !! will out flow Aluminum Edelbrocks out of the box....My C4's at .600" lift flow 295 Int. and 204 Exh... But that Full Port and Big Valve's... I have about $900 in them...
Russ
Old Nov 5, 2005 | 05:01 PM
fordeverpower's Avatar
fordeverpower
whats this lip you are talking about? The only thing that i had noticed on my d2te, is on the top of the port, that the exit is lower than mid point. I wanted to open the top of the port more, but with the gaskets and headers i couldn't. Is this the lip you are talking about? I don't recalled the floor having a lip, but they all have the curve on the port floor. DF, told me not to mess with that, i removed a SLIGHT amount of material and shaped it anyways.
Old Nov 5, 2005 | 05:13 PM
RapidRuss's Avatar
RapidRuss
Matt I think he's talking about smog hump heads...
Russ
Old Nov 5, 2005 | 05:26 PM
fordeverpower
Maybe, i had a set of smog d2te, but i gave them to the junk man when i couldn't beat the tubes out.
Old Nov 5, 2005 | 10:41 PM
fordraceboy
no... it's the outside of the turn when the port hits the headers... when you look at the head from the side, if you look at say the far left port- it would be the right hand side of that port... the last set i did i couldnt get that out...
Old Nov 6, 2005 | 07:03 AM
RapidRuss's Avatar
RapidRuss
I'am Confused now? LOL..I need a pic...show and tell...LOL..
Russ
Old Nov 6, 2005 | 11:46 AM
fordraceboy
ur right.. im confusing myself now!! i'll get some pix to help illustrate... probably cant see the exact spot but it'll show at least where i'm taking about.. hopefully... lol
Old Nov 6, 2005 | 02:58 PM
davethecow's Avatar
davethecow
If you want some small port heads find yourself an ft motor,there ports are tiny.
Old Nov 6, 2005 | 04:36 PM
fordeverpower
i honestly was dumbfounded too!
Old Nov 6, 2005 | 04:49 PM
fordraceboy
got tied up today...see if i can get the pix on monday...
Old Nov 7, 2005 | 07:43 PM
fordraceboy
i can't get my photo to com to this page... help!!
Old Nov 7, 2005 | 07:56 PM
fordraceboy
this port isnt as bad as the last set i ported out, i wish i knew the casting #'s on the other heads, these are D2TEAA... anyone know port sizes for them stock?
