Ignition Box
Old Nov 4, 2005 | 01:55 PM
Chumbucket's Avatar
Chumbucket
Ignition Box
Can you have spark to plug's and ignition box still keep from starting. 87 351W Thank's. Carb.motor
Old Nov 4, 2005 | 09:24 PM
Franklin2's Avatar
Franklin2
Not really. That is the module's job, to make spark. You need fuel and spark, and compression, and it should take off.
You may want to run the engine around till the timing mark on the crankshaft lines up with 0. Then take the dist cap off, and see if the rotor is pointing to #1 cylinder sparkplug wire. If it isn't, run the engine around exactly one more turn and see if it points to #1 sparkplug wire. If it doesn't, your timing chain may have jumped some teeth.
Old Nov 5, 2005 | 03:46 AM
Chumbucket's Avatar
Chumbucket
Ok, Dave I will check it out. Thank's
