Various trim removal
Old Apr 1, 2002 | 07:14 PM
orangeford's Avatar
orangeford
I am going to get my truck ready to be painted inside and out and have some questions about taking stuff off. First is the side emblems that say f150 How do those come off?
ranger
XLT
My truck is a 79 and has the letters f o r d on the hood, how do those come off?
I cant seem to figure out how the lower trim of the 77-79 racetrack chrome trim is removed I am too scared to pry on it because it is all in good shape.
One last thing is the woodgrain xlt ranger panel that goes on the glove box, how is that removed?
Do the shop manuals advertised on this site have this information?
Old Apr 1, 2002 | 08:38 PM
Mil1ion's Avatar
Mil1ion
All the emblems and hood letters pry off.
Use a small scraperwith a rag under the pry point.
They should slip right out.
Dennis
[font color =red]Calgary,Alberta,Canada [/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color =green]http://www.clubfte.com/users/mil1ion/Mil1ion.html[/font]
[font color =green]http://community.webshots.com/user/mil1ion[/font]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Apr 1, 2002 | 11:14 PM
thitdog's Avatar
thitdog
The woodgrain panel on the golvebox is affixed with double sided tape. I slowly started working it up with a putty knife and warm water. Go slow and easy and it will come off.
Lee
Old Apr 2, 2002 | 09:09 AM
beartracks's Avatar
beartracks
The small lover race track trim has both clips and studs/nuts holding it on. You will find the studs mostly at the ends. Some are behind the tail lights. It a pain but the only way to get a really good paint job is to get all that stuff off. You can also paint/polish it (another Pain) while it's off.
Bear Tracks
Old Apr 8, 2002 | 12:59 AM
orangeford's Avatar
orangeford
Thanks guys. I have one more question. What is the best way to take off the top main chrome trim? the metal clips on the ends scare me are you supposed to slide off the trim or just pull it off? then after the trim is off how do you remove the metal clips? whats the best way to put it all back on without messing up the paint? On the emblems how do they go back on?
Old Apr 8, 2002 | 11:20 AM
beartracks's Avatar
beartracks
The large trim also has some studs. At least one on each end. One of them is behing the door jam in the front. The others have to be reached from under neath I believe. Also behind the tail light. The rest of the large trim pieces are plastic clips that will snap off. Go slow.
Bear Tracks
Old Apr 8, 2002 | 01:35 PM
orangeford's Avatar
orangeford
how do the studs come off are they threaded or do they need to be grinded off?
Old Apr 9, 2002 | 09:54 AM
beartracks's Avatar
beartracks
The studs have a nut on them from the inside. You've got to find them and unscrew the nut. 3/8" or 7/16".
Bear
Old Apr 9, 2002 | 11:03 AM
petem's Avatar
petem
I removed the styleside? trim from my longbed recently and here is the order of operations I used:
First remove tail light lens to access rear trim stud.
Using 11/32 socket, remove nut from rear trim stud, pull back on trim gently, and then remove the stud from the trim (it looks like a closet bolt).
The second and final stud is underneath the wheel-well just in front of the rear tire. Use a 11/32 socket again to remove nut.
Now the plastic clips are the only thing holding the trim. I slid the trim back and forth (inch or so) a couple of times to make sure the clips weren't frozen to the trim.
Gently, only using my hands, I was able to get a finger or two inbetween the bed and the trim and I slowly unsnaped the trim one clip at a time.
Maybe someone here would know: Is the trim hardware still available from Ford? Thanks!
Old Apr 9, 2002 | 12:15 PM
Mil1ion's Avatar
Mil1ion
I don't know if ford has it but, the aftermarket does.
[i][font color=blue]Dennis[/font][i]
[font color=red]Calgary,Alberta,Canada[/font]
[i][font color=green]
http://www.clubfte.com/users/mil1ion/Mil1ion.html [/font][i]
Old Apr 10, 2002 | 11:21 AM
petem's Avatar
petem
I'm looking for the upper trim clips and studs for the bed moulding. I'm assuming the hardware is the same for the upper trim all the way around the truck, but I have only removed the bed moulding. I looked in LMC, AutoKrafters, and Dennis Carpenter and didn't see anything for the upper trim; any other suggestions? Thanks!!
Old Apr 10, 2002 | 12:13 PM
beartracks's Avatar
beartracks
The plastic clips and the metal stud for both top and bottom trim seem non existant. I'f anyone here has a source for any of these parts please post so I can stock up.
Bear Tracks
Old Apr 10, 2002 | 12:57 PM
79f3504x4's Avatar
79f3504x4
Jeffs Bronco Graveyard shows trim clip kit $65 +-.Brian
Old Apr 10, 2002 | 01:00 PM
Mil1ion's Avatar
Mil1ion
I have a pile of plastic clips but, I was going to include them with the excellent chrome I'm selling.
I think the studs are welded on,you have to use screws to mount the plastic clips.
Old Apr 10, 2002 | 08:10 PM
Graffe's Avatar
Graffe
