Modular V10 (6.8l)
OH My
Old Nov 3, 2005 | 08:59 PM
Wimmer's Avatar
Wimmer
OH My
It was the fuel pump.
I have never driven a truck with that much power.
I have owned the truck for about 2 months and I just thought it was bad, now I know..
Thanks everyone for the help. If we ever meet I owe all of you a drink.
Michael
Old Nov 4, 2005 | 12:25 AM
NoMo's Avatar
NoMo
Sorry to hear it was a more expensive repair than just a new filter, but at least it's fixed!
Welcome to the BSEG club.
Old Nov 4, 2005 | 07:19 AM
SLE's Avatar
SLE
Does it run like a spotted ape now?
Old Nov 4, 2005 | 11:58 AM
kamakazi's Avatar
kamakazi
My fuel pump went out on me after i got home from work (luckily). It only has 24k miles on it. I've been hearing that our fuel pumps are maxed out and they are weak and is usually the first to go? I had it replaced by the dealer with another OEM part. Hopefully, this was just a fluek?
Old Nov 4, 2005 | 02:01 PM
FortyFords's Avatar
FortyFords
Wimmer ,glad she's purriiiiiiiiiiiiiiiiiiiiiiiiinnnnnnnnn like tiger Now!
Rich
Old Nov 4, 2005 | 05:38 PM
valvestud's Avatar
valvestud
I almost hate to post and bring out the bad karma, but in 97,000 miles I've only replaced normal maintenance items, the 4 door lock actuators, and shift selector cable on my 2001 EX. The vehicle has been mechanically perfect since day one! I did replace the rotors with Art's, but that was after 30K miles.
Old Nov 8, 2005 | 10:27 AM
Coz77's Avatar
Coz77
Just got finished replacing my fuel pump. I tried NAPA but none of their parts fit. So I had to get it from the dealer. ($236) It wasn't to bad to change out. The dealer wanted $460 to do it. It was suggested to test the IAC (great thread on testing it on this sight), it check out ok. The truck is a '99 with 58k miles. I also had to change the passenger side door actuator. I will need to swap out the drivers side some day. Other than that the truck has done all that I have asked.
Old Nov 8, 2005 | 06:11 PM
Wimmer's Avatar
Wimmer
Oh yea She runs like spotted ape, on steroids. I can't get the BSEG off my face.
I got my fuel pump from a local parts house here in town. It is carquest brand, no one else had a listing for the thing. I paid 183.00.
I pulled my 28' TT this weekend, I probably could have pulled it 90 if I would have wanted to. My PSD never handled it like that.
Old Nov 8, 2005 | 06:20 PM
SuperdutyRob's Avatar
SuperdutyRob
Just to let you guys know, I picked up a Walbro 255 liter per hour fuel pump for 107 bucks. I have had great luck with the Walbros. I have one in my supercharged mustang. For the superduty, it is a direct bolt on, and you can't beat the price for a high powered racing fuel pump.
Old Nov 9, 2005 | 06:56 AM
Wimmer's Avatar
Wimmer
I considered an aftermarket pump , but was not sure how to do it.
Superduty Rob how do you have your's installed?
Old Nov 9, 2005 | 11:51 AM
valvestud's Avatar
valvestud
SuperdutyRob,
Can you tell us the part number and your source for our V10s?
Thanks,
Old Nov 9, 2005 | 01:57 PM
SuperdutyRob
Hey wimmer! I do all of the work on my truck myself. Everything. I installed the pump. It's very easy. All you have to do is unbolt the gas tank ( helps when it's empty), unplug the level sender, unscrew the top for the pick up. (need a large pair of pliers). Pull out the pickup and pump assembly, Unplug the fuel pump and take out the retaining screws, unscrew the hose clamps for the line, and install the new pump in the same manner.
Old Nov 9, 2005 | 01:58 PM
SuperdutyRob
valve stud, I will get you a part number on the pump. I do a lot of internet research, and I also have many freinds that work on modulars.
Old Nov 9, 2005 | 06:11 PM
Wimmer's Avatar
Wimmer
I do all my own work also, I googled walbro and went through their selection and did not see an intank for my 2000. I assumed you used an inline pump.
Old Nov 9, 2005 | 10:07 PM
SuperdutyRob
No, my setup is an in-tank one. I will deffinitely get part numbers for you. I've been busy. I've been workin on the house all day. I did a parts configuration in order to do the pump swap. I used their 255 lph pump, along with a superduty install kit. Worked like a charm. I also have an inline pumpon my truck for my supercharger. The inline pump is set on a relay, so it does not start pumping until my supercharger starts boosting.
