Another glowplug issue
Old Nov 3, 2005 | 04:03 PM
6.9FordMan's Avatar
6.9FordMan
alright, when I first got my truck I knew the glowplug system didn't work. So I replaced the coolant switch (because it was broken in half), and all 8 glow plugs. Still nothing, the "Wait to Start" lamp would always stay on. Then I replaced the Relay and the system started to work great!! One week after I got it working I went to my truck after work and it started right up, on my way home I noticed the "Wait to Start" lamp had come on again driving down the highway. Since then the glow plug system does NOT work. And now the Lamp goes on and off randomly while the engine is running, and it makes a "clicking" sound.
Old Nov 3, 2005 | 04:34 PM
Drover's Avatar
Drover
It sounds like your controller is bad. When the light is on your glow plugs are being heated. Most of the plugs don't handle being on for more than 10-15 seconds(oRless) at a time,so they may be burned out.Test them with a test light.If they are bad hopefully they haven't bent or swelled.The controllers are around the $100 mark,there are posts for switching to a manual system.
Old Nov 3, 2005 | 05:50 PM
trike1946's Avatar
trike1946
I would switch to a manual system. Check your gps and replace with Motorcraft/Beru only. Get the old ones out right away before you loose a tip. Disconnect your controller until you get it fixed. Plug the truck in at night if you need to until you fix the problem.
