1978 - 1996 Big Bronco
Ahhh!!
Old Nov 3, 2005 | 03:28 PM
Fordbronco95's Avatar
Fordbronco95
Ahhh!!
ok so all of a suddn driven today i go to give it gass and nothing happens . so i stop at a stop light give it half pedel and it had ****ed into first and wasnt moving. for about 5 secounds the truck had slowly started rolling and then started to pick up speed. I brought it to a automatic transmision shop and they say its engine performance related. i bring it to a friend of myn who is a ford master tec and he wasnt to sure but he didnt do any test's but drive it. now when i dont exceed half gas it dosnt do the symptom. he sort of thought it could be the first cat that could have sort of come apart and cloged up with the honey combs because u could hear them rattling when in park with gas. now when in park with gas it has no problem gaining rpms. in drive reverse and manual shift it has the symptom of not gaining rpms and not moving up to speed. could it be my torque converter? or something else im not really sure. my transmison oil level is good.
ps no check engine light
no flickering overdrive light
Old Nov 3, 2005 | 04:02 PM
Kemicalburns's Avatar
Kemicalburns
what year,motor,tranny are we talking about here. put this info into your sig so we dont have to ask ya anymore.
now could be a fuel issue, like bad pump or clogged filter. if your cat is clogged easiest way to check is disconnect the Y pipe from the manifolds and drive it around your house and if its improves there is your problem. also when was it tuned up last with plugs,cap,rotor and plugwires. scan the ecu for codes if its efi , it can be done easy with a paper clip go here www.fordfuelinjection.com to learn how. also check your tranny fluid level while the motor is running if it smells like rotten eggs then your tranny is toast
Old Nov 3, 2005 | 08:35 PM
Fordbronco95
1995 351w e40d trans cap/rotor plugs wires changed a less then 2 thousand miles ago fuel filter replaced less then 1000 miles ago engine has 110000 miles.same with trans. transmison oil is fine hot and cold and running dosnt smell was changed less then 300 miles ago with a new filter.
Old Nov 4, 2005 | 12:31 AM
greystreak92's Avatar
greystreak92
Pull the codes from the computer. This will give you a place to start looking. Anything that has the engine dying on you will generate an error code.
Art5
25
Oct 19, 2013 03:49 PM
TMF89
2004 - 2008 F150
Aug 18, 2011 10:55 PM
ford2002f150
1997 - 2003 F150
Mar 13, 2011 12:04 AM
laser92awd
1983 - 2012 Ranger & B-Series
Nov 21, 2005 02:10 PM
scottskingdom
Modular V8 (4.6L, 5.4L)
Mar 12, 2004 11:59 AM
