1978 - 1996 Big Bronco
79 Bronco front end
Old Nov 3, 2005 | 12:06 PM
Nohaj1's Avatar
Nohaj1
79 Bronco front end
Could anyone tell me what the stock front end options were in a 79 Bronco. Did any of them come with Dana 60's? Were they coil or leaf sprung setups? Excuse my ignorance I know F series trucks but not much about broncos. I tried searching but couldnt find any answers.
Thanks
Old Nov 3, 2005 | 12:41 PM
Ponyracer's Avatar
Ponyracer
the 79 Bronco will be the same as the F150 except for the front axle is weaker near the knuckles than the F150. So it will be coil sprung with trailing arms and a solid axle D44. Why do you ask?
Old Nov 3, 2005 | 12:52 PM
Kemicalburns's Avatar
Kemicalburns
why would the d44 be different between a bronco/f150 . they both use the exact same setup.
Old Nov 3, 2005 | 12:56 PM
Ponyracer's Avatar
Ponyracer
check out this site and you'll see. This guy has done extensive research on this for SAS swaps.
http://77cj.littlekeylime.com/Dana44.htm
Old Nov 3, 2005 | 12:59 PM
Ponyracer's Avatar
Ponyracer
DUH, I just reread it and it is the 78-79 F100 F150 and Bronco. I was tired the night I was doing research.
Old Nov 3, 2005 | 02:12 PM
Nohaj1's Avatar
Nohaj1
Thanks for the quick responses guys. I was just curious because a friend of mine is getting a 79 bronco to part out for his truck. He was under the impression that the front end was a dana 60. That didnt sound right to me so I figured that I'd ask the experts.
Old Nov 3, 2005 | 02:14 PM
Ponyracer's Avatar
Ponyracer
I'm not an expert in any way, I just have a lot of websites to answer my questions with.
Old Nov 3, 2005 | 02:37 PM
InkDawg's Avatar
InkDawg
My 95 Bronco has a front Dana 60.....
Old Nov 3, 2005 | 03:01 PM
Ponyracer's Avatar
Ponyracer
but its not stock unless it is a conversion from centurion and then its not a Bronco anymore it would be an F350 with a Bronco rearend grafted on. All F150's and Broncos came with the Dana 44 front end from the factory.
Old Nov 3, 2005 | 04:01 PM
InkDawg's Avatar
InkDawg
You are correct...I swapped in a D60 front and a Sterling rear...I run leaves though instead of coils. Much easier to swap in and cost less to do.
Old Nov 3, 2005 | 04:04 PM
Kemicalburns
its all good. i do it myself some times
Old Nov 6, 2005 | 01:38 AM
RRMike's Avatar
RRMike
Time to update the sig Pony
Go Ducks!!
Old Nov 6, 2005 | 09:58 AM
MBBFord's Avatar
MBBFord
What year is your friends truck? Either way everything is the same on the bronco as on the F-100/150 except for the rear quarter panels and the top.
Stock D44 3.50 gears front(coil springs) / Ford 9" 3.50 gears rear(leaf sprung)
NP203(full time) or 205(part time)t case.
Came with only a 351M or 400.
Basically all the same, but some different options.
Old Nov 6, 2005 | 01:48 PM
RRMike's Avatar
RRMike
While we're on the subject do the 78-79 Bronco's come with 28 or 31 spline 9"s? I was just guessing they would have 28 spline but it would be cool if they had a 31 spline axle.
Old Nov 6, 2005 | 06:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Mine's got 31 spline axles stock.
