Will an 87-91 Truck 302 bolt into a Foxbody?
Old 11-02-2005, 04:32 PM
mdjohnson's Avatar
mdjohnson
mdjohnson is offline
Question Will an 87-91 Truck 302 bolt into a Foxbody?
I have a 302 I'm rebuilding and the bolck was cast from 87 to 91 and I want to put it in a foxbody Mustang when I'm done. Will it bolt into any fowbody of just certain years.
Thanks
Old 11-02-2005, 05:06 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
yes it will bolt right in
Old 11-02-2005, 08:36 PM
mus4dad's Avatar
mus4dad
mus4dad is offline
yes, but....
Yes, it will bolt to the transmission, however you will have to change the oil pan to a dual sump and the oil pickup. You will also probably have to change over the engine mounts; not speaking of the rubber motor mounts, but the steal mount bracket coming out of the engine that the rubber mount hooks to.
Old 11-03-2005, 01:53 PM
AlfredB1979's Avatar
AlfredB1979
AlfredB1979 is offline
You *might* have to change over to the Mustang TB/intake mani as well.
The truck version is taller, I believe. Of course, if that is really the case, get a cowl induction hood then.
Foxbody408
07-21-2015 04:25 AM
Deadsquiggles
106
09-03-2014 03:26 PM
orangeRcode
New Member Introductions
06-19-2014 12:14 PM
foxbody429
12-25-2012 08:31 AM
purgeofdarkness
12-23-2010 05:53 AM
Quick Reply: Will an 87-91 Truck 302 bolt into a Foxbody?
