Brake Problem
Old Mar 31, 2002 | 11:57 PM
F350SuperCab4x4's Avatar
F350SuperCab4x4
Brake Problem
i just got a 78 f250 supercab 4x4 and the guy i got it from put a dana 60 in the front and dana 70 in the rear, so i guess you can say it's a f350. anyway in the past 2 years he replced all the brake components, booster, master, calipers, rotors, wheel cylinders, EXCEPT the proportioning valve. i dont know how the brakes worked before he changed the axles, will have to ask him. my problem is the truck just doesnt have that good of stopping power. the brakes feel like they are manual not power. i cant even get the backs to lock up. the tire's are alittle bigger then stock, 16" outlaw rims and a 285 tire.so it's not like i have 44" tire's on it. and the truck almost weighs 7000lbs. i had another 78 supercab 4x4 250 2 years ago with the same problem but i sold it before moving to Phoenix,AZ. so i didnt have the chance to fix it. my question is will i have to change the proportioning valve because of the bigger axles or is the valve just bad. or is that even the problem.i know the valve is not cheap so i just dont want to buy one and still have the same problem. would appreciate any help with this. Paul
Old Apr 1, 2002 | 02:53 PM
Mil1ion's Avatar
Mil1ion
Brake Problem
Is that new booster for a F250 or a F350 ?
Are the rear brakes set right up to just barely touching the drum?
Otherwise,the P V probably needs replacing.
Dennis
[font color =red]Calgary,Alberta,Canada [/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color =green]http://www.clubfte.com/users/mil1ion/Mil1ion.html[/font]
[font color =green]http://community.webshots.com/user/mil1ion[/font]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Apr 1, 2002 | 08:33 PM
F350SuperCab4x4
Brake Problem
i didnt know there was a difference in boosters between the 250 and 350, is there? i cant check the brakes until the truck gets shipped to phx. i'm just trying to get a head start on the problem before it gets here. which should be 2 1/2 weeks. i do know the pedel wasnt low. it was just hard like trying to stop a car with power brakes when the motor is off.
Old Apr 1, 2002 | 08:50 PM
Mil1ion's Avatar
Mil1ion
Brake Problem
The booster for the 350 is a up-grade for the 150/250.
Something else <it could be the plunger rod from the booster to the M/C is out of adjustment.
Dennis
Old Apr 15, 2002 | 10:10 PM
F350SuperCab4x4
Brake Problem
dennis
i got the truck a few days ago. so how do i adjust the plunger rod. how long should it be, i never done this before.
Paul
Old Apr 15, 2002 | 10:51 PM
proford460's Avatar
proford460
Brake Problem
Make sure the brake wire for the PV is plugged in; make sure the valve hasn't shifted to the rear shutting off the fluid ie it thinks there is a leak. sometimes if you bleed the brakes too fast or inproper the valve shifts and no fluid.
Old Apr 15, 2002 | 10:56 PM
Mil1ion's Avatar
Mil1ion
Brake Problem
