Help head unit install
Old Nov 1, 2005 | 05:50 PM
goodballs87's Avatar
goodballs87
Exclamation Help head unit install
Ok so this is my first 2005 f-150 install. Everything was going fine, took off dash piece easily and hooked up witrign harness and all. Then i looked at the scosche mounting kit and started to wonder how will my pioneer single din unit mount snugly into this kit?? because when i removed the factory unit it was held on by the four screws and was suspended by them. Shouldn't there be a metal bracket that the head unit will screw into so it will not move around????? Hopefully i'm being decriptive enough for you all.
Old Nov 1, 2005 | 09:21 PM
atuck23's Avatar
atuck23
Where did you get the unit?
