Sponsored by: Real Truck
trac bar install help !!!
Old Nov 1, 2005 | 04:03 PM
mattd17's Avatar
mattd17
hi all, i just installed the pro comp leveling kit into my 99f250 sd 4x4. well, i cannot seem to get the trac bar re-installed, and was wondering what any of you guys have done in the past. also, how long should it take for the springs to settle? right now my nose if about 1-1.5 inches higher than the rear, even with the 4 inch block. thanks in advance !!
Old Nov 1, 2005 | 04:29 PM
99f350sd's Avatar
99f350sd
I drive one tire up a steep incline to compress the suspension. You may have to play with one side or another. I always get it pretty easy..
Old Nov 1, 2005 | 05:33 PM
mizzitch's Avatar
mizzitch
Or you could put a ratchet tie down strap around the front axle on each side and hook to the frame. I have done this to reattach the trac bar - works well.
Old Nov 1, 2005 | 05:36 PM
mtgrzlyman's Avatar
mtgrzlyman
i just had a guy turn my wheel until it lined up.
Old Nov 1, 2005 | 05:51 PM
texcan's Avatar
texcan
Do as Mtgrzlyman Said! Turn it to the right then have them turn ti the left until you can shove the bolt through!
Old Nov 1, 2005 | 06:05 PM
mattd17's Avatar
mattd17
sounds good thanks for the advice !! i will try it tomorrow and see what happens. how long should it take for the springs to settle? i have a nose up look, and may have to put in an add-a-leaf if it doesnt change. thanks !!
Old Nov 1, 2005 | 06:44 PM
99f350sd's Avatar
99f350sd
Months to settle or years. Or take it off some jumps that will do it LOL.
Dick
Old Nov 2, 2005 | 09:43 AM
mtgrzlyman's Avatar
mtgrzlyman
dought it will settle 1 1/2-2 inches
Old Nov 2, 2005 | 11:29 PM
mattd17's Avatar
mattd17
well, i am finally finished, and your tricks worked great. thanks for all the help !!! i will post some pics in a couple days .... thanks again !!!
