Sponsored by: Auxito
Help with Ford Silver Remote Starter
Old Nov 1, 2005 | 03:41 PM
firefytr29wfd's Avatar
firefytr29wfd
I am installing a Ford Silver Remote Start/Keyless Entry. Got everything in except for the PATS bypass. A few questions about it...
1) Where does the white wire get attached to?
2) How do you program it to learn the key code?
Thanks for any help
Jason
Old Nov 1, 2005 | 05:29 PM
code_red's Avatar
code_red
hello jason, I wont be able to help you with your questions , but i can tell you that you might have some luck in finding your answers buy doing a search on the topic in this forum. Im sure someone will come along here eventually with some insight on the start/keyless entry, for now try your search, it works wonders
Old Nov 2, 2005 | 12:32 AM
Racerguy's Avatar
Racerguy
You might also find more answers on www.gemsen.com/ford
Old Nov 2, 2005 | 11:24 AM
firefytr29wfd
I used gemsen for info on how to install the starter system, but I cannot find anything related to the PATS bypass kit on there....
Old Nov 2, 2005 | 11:36 AM
MrBSS's Avatar
MrBSS
I put in a Ford "Gold" remote start/ security system which I assume is similar. I can dig out the instructions if this doesn't help, but going from memory, the ring around the ignition lock plugs into a PATS override module which plugs into the main rs/s system module. I think the code was programmed as part of the start-up procedure (where you push the override button to make settings).
Old Nov 8, 2005 | 06:46 PM
firefytr29wfd
Thanks for all the help with my install, did it Saturday, took me about 3 hours total. Lots less than the 10 the dealer told me it would take them..........
