93 explore help!
Old Nov 1, 2005 | 01:01 AM
pmpdavid86's Avatar
pmpdavid86
93 explore help!
Hey, gotta problem with my explorer 93 v6 4.0 eddie bauer....it doesn`t wanna go over 55mph and2500rpm takes a lot of gas and ford dealership mechanics dont know whats the problem. I am hopeless please help me, Thank u
Ps: no ovearheating, gas preassure allright, oil too..
Old Nov 1, 2005 | 02:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 1, 2005 | 04:49 AM
marragtop's Avatar
marragtop
One thing that comes to mind is a clogged cat converter. What kind of tests did the dealer perform?
Old Nov 1, 2005 | 12:11 PM
pmpdavid86's Avatar
pmpdavid86
The just plugged the computer to my car, told me that its barelly comunicating and that gas is getting in my oil... Told me to wait for their technician to look through it ($350)
Old Nov 1, 2005 | 12:24 PM
Jharger's Avatar
Jharger
Going to need some more info. Can you isolate any of the 3 basics? Air/Fuel/Spark.
You can go to a local autoparts where they can run a code diagnostic and help direct the issue, possibly.
Old Nov 1, 2005 | 02:20 PM
mrshorty's Avatar
mrshorty
What does it mean they are "barely communicating?" I know their shop computer is probably pretty fancy, but your '93 uses an old-fashioned EEC-IV computer. Did anyone try pulling codes the poor man's way with just a jumper wire and a voltmeter/test light/check engine light (see tech article in Ken00's tech info post in Bronco II forum)? I'm sure there are some possible issues with communicating with an EEC-IV computer, but pulling trouble codes shouldn't be one of them.
When you checked fuel pressure, did you check for gasoline in the vacuum line to the fuel pressure regulator? That's one somewhat common failure mode for the FPR.
