Rear Signals
Old Oct 30, 2005 | 10:05 PM
realmcoy's Avatar
realmcoy
Unhappy Rear Signals
Hi Im having a problem wiring up rear turn signals. I have a 55 F100 and got the tail and brake lights working fine. I dont know how to do the circuit for the flasher. Do I run the turn and brake together or will there be feed back to the brake switch. Thank for the help. Roy
Old Oct 30, 2005 | 11:00 PM
51frrdtrk's Avatar
51frrdtrk
Don't think i can be of any help. You may want to drop down to the electrical forum and do a posting there. Is your turn signal control in the steering column or is it a add on.
Most of the time the add ons require a seperate bulb from the break light. On my 51 the turn signals are a totally seperate system.
Old Oct 30, 2005 | 11:12 PM
realmcoy's Avatar
realmcoy
Its an add on. Hey thanks for the reply. Ill try the electrical section.
Old Oct 31, 2005 | 12:31 AM
Earl's Avatar
Earl
Do you have an electrical schematic? If not, there is one here http://www.clubfte.com/users/earl/Re..._Material.html
Old Oct 31, 2005 | 06:51 PM
realmcoy's Avatar
realmcoy
Thanks Earl I appreciate the help.
Old Oct 31, 2005 | 08:01 PM
51ford fan's Avatar
51ford fan
Roy, I just sent you an e-mail
Rod
