351/460 same 5-speed?
Old Oct 30, 2005 | 08:30 PM
fiatman71's Avatar
fiatman71
Hello,
I tried searching for this and could not find much info. I'm considering purchasing a 87-91 F-250 4x4 extended cab with a 5-speed. I do not care really if the truck is a 460 or a 351. But I was wondering, do these engines have a different manual tranny behind them, and if so, which is the least problematic unit?
Any wisdom is appreciated. I might have to just get what I find as the manual tranny's seem fairly rare in these units. Thanks.
Old Oct 30, 2005 | 09:08 PM
handyman43358's Avatar
handyman43358
As far as I know, the 460 and 351 both had the ZF 5 speed tranny. The only thing I dont know is if the bell housing patterns are the same. The ZF is a great tranny, pretty indestructible. I think these also came with the old T-18 or similar tranny (4 speed with granny gear). Although I havent seen that tranny bolted up to anything except for a 300 inline, it very well could have been used with the 351. Hopefully someone else will be able to answer your question more thoroughly than I have.
Old Oct 30, 2005 | 09:09 PM
whiteyfordzx5's Avatar
whiteyfordzx5
my understanding is that the 460 uses a version of the ZF which has an external slave whereas the 351 is internal (concentric).
Mike
Old Oct 30, 2005 | 09:12 PM
pfogle's Avatar
pfogle
Yes the bellhousings are different too.
Old Oct 30, 2005 | 09:17 PM
handyman43358
Would he be able to switch between the two if he wanted to? Like swap parts to make a 460 tranny work with the 351 and vice versa? I've actually been curious about this also...
Old Oct 30, 2005 | 09:30 PM
EPNCSU2006's Avatar
EPNCSU2006
The bellhousings are integral with the transmission case, so in that respect, they aren't swappable. The internals may be the same, but I don't know.
