steering shaft help
Old Oct 30, 2005 | 07:40 PM
draglink's Avatar
draglink
steering shaft help
Hello, I have a '79 Supercab 4x4. The truck has a 351m, C6, power steering. The coupler that attaches the shaft to the steering box has a lot of play and needs to be replaced. This shaft does not have a rag-joint, just this coupler. How do I replace it? Do I loosen the nut, slide the coupler toward the firewall, then when loose from the steering box shaft, remove and reinstall the new one, or is there more to it??
Old Oct 30, 2005 | 08:35 PM
Mil1ion's Avatar
Mil1ion
You need a 12 point > 12mm or 7/16" socket.
You will see the bolt this fits on > both ends of the coupler shaft.
Loosen both of these to slide the coupler off.
