Sponsored by: Auxito
Annoying Intake Noise!
Old Oct 30, 2005 | 01:11 PM
AlkalineOne's Avatar
AlkalineOne
Exclamation Annoying Intake Noise!
i installed an Air-Aid intake system on my 4.2L and have noticed a loud "hissing" noise which doesn't seem right. i hear is when the truck is choked especially, but i assume that is normal. where is gets me most is when i am on the highway and only applying soft pressure on the throttle but goes away when accelerating. am i being too picky or is this normal???
Old Oct 30, 2005 | 06:34 PM
smits03's Avatar
smits03
This is completely normal, the hissing sound that you hear is the air being sucked in through the air filter.
Old Oct 30, 2005 | 08:03 PM
AlkalineOne
yea, i thought it was the air being sucked through... i just wasnt sure if it should be as loud as it is. thanks
Old Oct 30, 2005 | 09:15 PM
Flaw's Avatar
Flaw
I agree with the reply by smits03 - I have the Air Aid System on my 5.4 and if the sound is like the sound you get when you suck air through your teeth when you clench them together, then thats it. Your truck can truly breath now, so congrats on the Air Aid system.
Old Dec 19, 2005 | 03:41 PM
Oil-Pig's Avatar
Oil-Pig
I get the same sound during acceleration but the thing that bothers me is when I let off it sounds like I have air brakes. It sounds like air pressure escaping from somewhere??? Is this normal??
Old Dec 19, 2005 | 08:24 PM
fbodyfan's Avatar
fbodyfan
Yes, my K&N does the same thing, it's just the harmonics inside the intake tubing when the throttle body closes and changes the flow path of the air. This all also happens inside your stock system, but the air silencer over the filter and plastic intake tubing with ridges deafens this sound.
