white smoke
Old Oct 30, 2005 | 12:29 PM
Firemedic61's Avatar
Firemedic61
white smoke
In the mornings when it is cold and I have not plugged in my truck it blows some white smoke, then black when I first pull away from my house. Is this normal?
Old Oct 30, 2005 | 03:29 PM
buba 11's Avatar
buba 11
Cold smoke from a powerstroke, could be normal. I have personally never ever seen my 04 smoke ever and that was even on a 0 degree day. You may have an injector on the way out (but I think that missing cylinders from bad injectors throw trouble codes) or mabey it is something to do with the EGR valve who knows. I say if it clears up after a minute or so and tows good keep your eye on it and leave it alone!
Hey, I take it back, I used to see some smoke when it was really cold, but that was a couple of flashes (calibration changes) ago.
Old Oct 30, 2005 | 07:37 PM
DMAX-HD's Avatar
DMAX-HD
I live in Wisconsin - when it's cold - we all smoke a little on start-up. I'd only be concerned if you were white-smoking after you've warmed up. Then, yes, it is possible an injector is going bad. White-smoke is usually a sign of moisture in the system.
Old Oct 30, 2005 | 07:50 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Also this just might be condensation in the exhaust burning off. I've had this on some very moist mornings and would clear up after exhaust got a little heat to it. How does it run? If ok then I wouldn't worry too much.
Old Oct 30, 2005 | 09:05 PM
Firemedic61
Truck runs fine, had some warranty work done in August since then no issues. This is my first Diesel, so I am full of all kinds of questions. I notice that when the truck is plugged in at night it does not smoke at all. When it is not the smoke only lasts a second or two. Thanks for the info.
