I have a 2003 F-150 with a 4.6l V-8. Nuthin special about it. I just bought a Diablo Delta chip for it, but I also want to add a supercharger or procharger setup to it. Anybody know if the setups from the SVTs or Harleys will bolt on with much more than a head swap? Basically, I want to take everything from the Intake ..up, and swap it over, and obviously add the intercooler assembly. I know the stroke is different, but basically they are the same engine, correct? Can I still have A/C and everything else? If it can be done, please give details.
Because yours if a 4.6, you should be looking at the Cobra setup instead of the HD's and L's being that they are 5.4's.
Now I'm not sure about the components/accessories; you'd have to look closely at the placement of both and see if it is doable. As far as the chip goes, if you boost it, you'll need to send it back to your dealer to have it reprogrammed.
