Electrical Problem?
Old Oct 30, 2005 | 09:13 AM
Gregorri's Avatar
Gregorri
Question Electrical Problem?
My truck had been sitting for a few years jumped in it and tried to start it. I hear a click clunk noise at the soleniod. Replace it and she fires right up. A few starts later I I hear the same noise. This time its the starter. Which I figured would probably need replacing anyways. I buy a brand new starter and it starts fine that night, probably started it up three times or so. The next day I go to start it and it does the clunk/ click thing. The new starter is some how dead too. Any ideas as to what could be causing this? This will be the third starter on the truck, and I'll keep it off until I have some ideas as to why my starters keep dieing on me.
Thanks,
Rick
Old Oct 30, 2005 | 06:26 PM
Beast12's Avatar
Beast12
Are you sure it is the starters? Maybe you need new battery cables (especially grounds). On my old 85 I ran an extra ground from the negative to one of the bolts that hold the starter on. Just a thought.
-Matt
Old Nov 6, 2005 | 01:16 AM
rls302s's Avatar
rls302s
Angry Click Clunk, Solinoid,Starter???
My truck's (yes more than one), have done this same thing along with my E-150 Van's and the problem was always the battery cables, if I had known this the first time I would have saved some bucks by not buying parts I did not need. But I was young & dumb then.
This has been a Ford problem ever since I can remember as I don't recall
not having one for any long period of time when I didn't have to replace at least one battery cable.
Ron
Old Nov 6, 2005 | 01:31 AM
sierraben's Avatar
sierraben
Same here with my 81 F150, on the battery cables, especially the ground cable on the battery side.
That's why I always have a box end wrench handy in the glove box.
Old Nov 6, 2005 | 09:15 AM
Gregorri's Avatar
Gregorri
I going to go buy some new battery cables this morning, will post results within a day or two. I finally have some to time to go play with my truck today.
Thanks for your help,
Rick
Old Nov 6, 2005 | 12:01 PM
Bdox's Avatar
Bdox
Ron
This is not just a Ford problem, this is an automotive problem. It stems from most manufacturers using mimimum spec cables, and any corrosion or increase in resistance the cables causes failures. I used to make and sell custom cables. I did a lot of research on the subject and found that starting circuits amperage requirements vary widely in different conditions. My solutions was to make cables using 00 welding cable.
Old Nov 7, 2005 | 12:25 PM
Piffery1's Avatar
Piffery1
Common problem on many older vehicles of all makes/models. First thing I do to eliminate a ground problem is put a jumper cable from the (-) battery terminal directly to a good spot on the engine block and see if it cranks.
Old Nov 8, 2005 | 07:01 PM
Gregorri's Avatar
Gregorri
Smile
I replaced all the battery cables. Solved my problem. Winter is just around the corner so I better put the project in high gear so I can have it done. Having 4 wheel drive sure helps when trying to get out of a laneway 300 feet long that it full of snow...
Thanks for the help,
Rick
Old Nov 8, 2005 | 07:37 PM
Beast12's Avatar
Beast12
HAHA! What do I win? Maybe your old cables? Glad you got it fixed.
-Matt
Old Nov 8, 2005 | 07:50 PM
sierraben's Avatar
sierraben
There's money in them there copper.
Old Nov 8, 2005 | 09:20 PM
Gregorri's Avatar
Gregorri
Matt you can have them if you want them lol, I'm about a hour and change away from you, in St. Thomas.
Rick
Old Nov 9, 2005 | 05:03 AM
Beast12's Avatar
Beast12
SWEET! I'll be there in an hour!
-Matt
