Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Key Removal
Old Oct 30, 2005 | 01:18 AM
escapaid's Avatar
escapaid
Unhappy Key Removal
Hi All. New to forum, got a problem, can't get key out of ignition switch.
It will come out at times but mostly stays stuck, using remote to get in.
Any help would be greatly appreciated.
Old Oct 30, 2005 | 06:47 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 30, 2005 | 12:46 PM
Nitramjr's Avatar
Nitramjr
The next time it gets stuck in the ignition, try turning the ignition key a little in either direction. It probably isn't lining up perfectly in the off position.
Welcome, by the way.
Ray
Old Oct 31, 2005 | 12:49 PM
escapaid's Avatar
escapaid
Unhappy Tried it
I turned, wriggled and everthing else when stuck, but no luck. MY Daughter had a Pontiac that the key would go in but not turn, they had to replace the switch. I'm wondering if this may be my case, somtimes it acts like the gear selector isn't engaging park all the way. In fact the other day it rolled backward down the driveway.
Old Oct 31, 2005 | 03:11 PM
Nitramjr's Avatar
Nitramjr
Shoot, I forgot that in pre-2005 Escapes the shifter is on the column. They put them on the floor starting in '05 models.
Have you tried pulling the shift lever to the top, holding it there and then turning the key? I forget which car I had that this was necessary but it might help. Definitely sounds like something isn't lining up correctly.
Sorry if that doesn't help any more than my first response. Good luck.
