PCV valve check procedure
Anyway the test is simply to have the engine warmed up and idling. Remove the oil filler cap and apply a piece of paper larger than the opening to the opening. If the engine is healthy, and pcv is operating properly, the paper will be lightly but positively sucked onto the filler opening and will be retained there. A corollary to this is that you should not see oily vapors flowing out of the filler tube.
Is this test perfect? No. A worn out engine with lots of blowby will swamp the system and the paper will not be retained. But in a reasonably healthy engine, this test has worked well and served me well for many years.
My box of rox sounding 91 4.0 with 186000 miles still passes this test, go figure.
Ken
