89 f 150 problems
Old Oct 29, 2005 | 06:40 PM
aksnowking's Avatar
aksnowking
89 f 150 problems
well i have a 89 f 150 with the 302 in it i have a manual when im at a stop light or sign it will stall i cleaned IAC and it still does it i cleaned it with carb cleaner what else can be wrong?and i have a new fuel filter for it but how do you re preasureize it once your all done?
Old Oct 29, 2005 | 06:44 PM
Popa Tim's Avatar
Popa Tim
To re-pressurize the fuel system, just turn the key to 'ON' a few times but don't start her. Let is sit on on for two seconds before turning it off and back on.
Just be sure to re-engage the impact switch (inertia switch) first.
Cheers,
Tim
Old Oct 30, 2005 | 07:12 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
…..See you on the boards.
Old Oct 30, 2005 | 04:07 PM
aksnowking's Avatar
aksnowking
whats the inertia switch? and weres it located and i heard the way to depressierize it is unhook a sensor and run it out of gas weres the sensor at?
Old Oct 30, 2005 | 06:49 PM
Popa Tim's Avatar
Popa Tim
The intertia switch, sometimes called the impact sensor, is a safety device that will kill the power to the fuel pump(s) in the event of a collision. Its a spring loaded breaker switch thats held closed by a magnect. A strong jar will bounce the switch off the magnet and break the circuit. the spring will keep it open until you press it back down.
In a 94 its in cab behind the passengerside kickpanel. Thats the plastic peice to the left of the passengers calf/leg, just under the dash and forward of the door. Theres a red button on top of it it, you pull it up to open the circuit (no power to pumps.)
To depressurize the system you start the truck with the inertia switch open and let it run until it dies (basically it runs out of gas).
Many people depressurize buy holding a rag around the Shrader valve on the fuel rail and pressing it in. Of course this is with the engine off and the cigs well out of reach
Old Oct 31, 2005 | 10:57 AM
88f250hd's Avatar
88f250hd
The stalling could your tps. these may not always throw a code when they go bad. I had the same problem on my 88 f-250. I talked to a mechanic friend, and that is the suggestion he had. Replaced the tps and the problem went away. good luck.
Old Nov 5, 2005 | 04:20 PM
neoflee's Avatar
neoflee
When your tps was going bad what were the symptoms?
seths89f150
Jun 22, 2010 06:17 AM
timberon94f350
Jul 21, 2009 09:25 PM
Cruiseomatic
May 28, 2005 03:40 PM
mxkris
Aug 12, 2004 05:19 PM
sotxford
Dec 1, 2003 07:55 PM
