Tranny leaking
Old Oct 29, 2005 | 02:39 PM
REDONE97's Avatar
REDONE97
Tranny leaking
I have a leak in my 97 4.2 f-150 transmission. At first I thought that it was the gasket because I had put a cork gasket (stupid!) but I have since replaced it with a factory one. The leak went down from about having to put in a quart every two days to maybe one a week. This after driving about 30 miles a day. but i still have a leak and am not a great mechanic do the transmission leak sealers work well? About 88,000 miles on transmission.
Old Oct 30, 2005 | 01:34 AM
ivanribic's Avatar
ivanribic
I don't remember the brand but I used a tranny stop leak in my woman's truck and it never dripped another drop. They basically soften up the gaskets so they'll expand and seal better. I'd definitely recommend giving it a try though it sounds like your leak is pretty bad and I don't know if it can seal that much flow.
Old Oct 30, 2005 | 01:37 AM
ford390gashog's Avatar
ford390gashog
is it the pan gasket? the oem gasket has metal bands to prevent this also you must torque them to the correct pressure. leak sealer is basically brake fluid. it will swell gaskets twice there size. but it is not good for other items.
Old Oct 30, 2005 | 04:33 PM
REDONE97's Avatar
REDONE97
I have tightened the pan gasket several times not to torque spec but I think that the leak is coming from somewhere else.
77mud
1997 - 2003 F150
Jan 27, 2013 08:11 PM
RustyBeach77
1997 - 2003 F150
Jul 19, 2012 01:16 PM
raduque
Aug 23, 2009 01:30 PM
CarCrazy1001
Aerostar
15
Jan 25, 2008 07:55 PM
QFD90
Oct 13, 2005 07:05 PM
