Overhead electronics and radio issues
Does anyone know any electrical checks I can do for that system?
On a side note, Has anyone ever had issues with their radios lasting? My factory CD player went out 3 times (usually every summer) before i finally bought a new one. That went out the first or second summer i had it. I got it fixed and its been fine for the last 4 years or so, but now i'm having more problems with it. I don't know if its over heating or delivering too much power. Any ideas?
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shape id=_x0000_i1025 style="WIDTH: 6in; HEIGHT: 528pt" type="#_x0000_t75"><v:imagedata o:title='\\\\\\\"\\\\\\\"' src="file:///C:/WINDOWS/TEMP/msoclip1/01/clip_image001.png">
Pin Number Circuit Circuit Function
1 767 (LB/O) Ambient Temperature Sensor Ground
2 233 (DB/Y) Ambient Temperature Sensor Feed
3 19 (LB/R) Instrument Illumination
4 Not Used
5 53 (BK/LB) Courtesy Lamps
6 54 (LG/Y) Battery Saver Input
7 679 (GY/BK) Vehicle Speed Input
8 296 (W/P) Ignition (Hot in RUN)
9 57 (BK) Ground Circuit
10 Not Used
<v:shape id=_x0000_i1025 style="WIDTH: 6in; HEIGHT: 528pt" type="#_x0000_t75"><v:imagedata o:title='\\\\\\"\\\\\\"' src="file:///C:/WINDOWS/TEMP/msoclip1/01/clip_image001.png"></v:imagedata></v:shape>
VOLTAGE CHECK
Remove one screw retaining overhead console to roof.
Disconnect the 10-pin connector.
Key to RUN.
Using Rotunda Digital Volt-Ohmmeter 014-00407 or equivalent, verify that voltage is present on Pin 3, Circuit 19 (LB/R) and that it varies as the dimmer rheostat is rotated.
Does voltage vary?
Yes
REPLACE compass and thermometer. RETEST system.
No
SERVICE wiring back to dimmer rheostat. RETEST system.
<O
</O
POWER SUPPLY CHECK
Key to RUN.
Using Rotunda Digital Volt-Ohmmeter 014-00407 or equivalent, verify battery voltage on Pin 8, Circuit 296 (W/P).
Is battery voltage present?
<O
</O
Yes
No
SERVICE wiring or ignition switch. RETEST system.
http://www.fullsizebronco.com/forum/...+console%22%22
