A4LD slipping
Old Oct 29, 2005 | 10:39 AM
gracepastor's Avatar
gracepastor
A4LD slipping
My son has an '87 Ranger with the 2.3 and A4LD. The tranny does not engage in R and D. When I shift to R I get high revs and very little movement. In OD it does fine in 1 and 2 but when it upshifts to D again high revs. I replaced the filter, with no improvement. Could it be the vacuum modulator? Also, if band adjustment is needed can that be done without dropping the tranny. I know the valve body is accessible by dropping the pan. Could that be where the issue is. I couldn't find anything that seemed to describe this issue on the forum, so I am just shooting some ideas out there. Any thoughts?
Larry
Old Oct 29, 2005 | 03:55 PM
NitrousAl's Avatar
NitrousAl
I'd take it to a transmission shop. It may need a rebuild. Don't go to a chain like AAMCO or Cottman's. Find a good local shop and get an estimate before they do the work.
Old Oct 29, 2005 | 06:53 PM
rclarke's Avatar
rclarke
No reverse and no third gear indicates a bad direct clutch. time for an overhaul.
