new bushings?????
Old Apr 20, 2002 | 09:46 PM
TCTOOL's Avatar
TCTOOL
new bushings?????
I think I need and want to replace all of the bushings in my front end. Its a '76 F-150. I havent researched it yet but what is involved and can I do it myself??
Old Apr 21, 2002 | 12:03 AM
tetraruby's Avatar
tetraruby
new bushings?????
2WD or 4X?
Old Apr 21, 2002 | 11:10 AM
TCTOOL's Avatar
TCTOOL
new bushings?????
Sorry, that would make a difference. It's a 2WD
Old Apr 21, 2002 | 12:50 PM
73Custom's Avatar
73Custom
new bushings?????
Yes you can do it yourself. You will need a floor jack and jackstands along with normal hand tools. I strongly recommend replacing both the radius arm bushing and the axle pivot bushing with new poly bushing - stronger and last longer than rubber, at the same cost. Do a search of the past posts, this has been covered many times. This thread will help you:
https://www.ford-trucks.com/dcforum/61_79/9624.html
I did mine several months ago, cost me $50 for poly bushings - it was worth every penny... Go for it!
Marty
Old Apr 21, 2002 | 09:32 PM
f10074's Avatar
f10074
new bushings?????
Where did you get your poly bushings? was it a 2wd or 4wd? thanks
-- William (Tony) Whited
74 F350 Ranger XLT Super Camper Special 460
77 F150 Custom 460
77 F250 Custom 460 (parts truck)
El Paso, TX Semper Fi
Old Apr 22, 2002 | 05:41 AM
Blaine's Avatar
Blaine
new bushings?????
Do you need to remove the springs to do the pivot bushing?
Old Apr 22, 2002 | 11:51 AM
tetraruby's Avatar
tetraruby
new bushings?????
It would be real tough to try to do the pivot bushings while under the truck. Likewise, it would be akward to handle the I-beam with the spring still attached. I can't remember the exact steps I took to remove the springs when I did mine, but while I was at it, I did the springs and king pins/bushings too. What started out as a cheap project grew to some expense, but it's nice to know everything has been refurbished on the front end. I ended up taking the beams with spindles attached to a shop to have them do the press work and honing for the king pin bushings. Will probably be stinky if your going to try burning out the old rubber in the pivot bushings. Wear a mask...
Old Apr 22, 2002 | 03:35 PM
73Custom's Avatar
73Custom
Post new bushings?????
I got my poly bushings from LMC Truck, about $50 for both the pivot and the radius arm bushings.
I found that it is MUCH easier to remove and install the Ibeams with the coil spring removed. It only takes one bolt in the upper clamp and a large 1 1/8" nut on the bottom to remove the spring.
Marty
Old Apr 23, 2002 | 06:36 AM
Blaine's Avatar
Blaine
new bushings?????
doyou need to compress the spring?
Old Apr 24, 2002 | 09:00 AM
73Custom's Avatar
73Custom
new bushings?????
'doyou need to compress the spring? '
No. Put the front up on jackstands, so the tires are off the ground. Then (with tire off) put a floor jack under the front beam, remove the top clamp on the spring and one end of shock and lower beam down.
Marty
Old Apr 24, 2002 | 09:33 PM
wl_keller's Avatar
wl_keller
new bushings?????
I am getting ready to replace the bushings in my 78.
I've seen the ones at LMC (energy suspension) and a set from a company called prothane from JC Whitney. Is either better than the other?
Is it true that poly bushings squeak?
Old Apr 25, 2002 | 08:39 AM
73Custom's Avatar
73Custom
new bushings?????
'Is it true that poly bushings squeak?'
I've had mine in my daily driver since last summer and they are silent. The LMC bushings come with some lube that you put on the bushings as you install them - that probably helps eliminate the squeak.
Marty
Old Apr 25, 2002 | 11:34 AM
brents's Avatar
brents
new bushings?????
ManfredVonRichtofen
1978 - 1996 Big Bronco
Feb 17, 2013 02:55 AM
thendrix
Apr 26, 2008 01:14 AM
chrisa
Aerostar
Jun 10, 2002 08:00 AM
inliner
May 21, 2002 05:26 PM
