50k miles pulling 5th wheel - avoid?
Old Oct 28, 2005 | 07:14 PM
ssgnai's Avatar
ssgnai
I'm looking at an 88 F250 with 80,000 miles and the guy wants $1875 for it. Its the big engine and extended cab, but not 4x4. He pulled a fifth wheel with it and "can't remember ever changing the tranny fluid". He says if it sits a month it has trouble moving before its warmed up. The price looks interesting, but I'm wondering if I should avoid it nonetheless.
Old Oct 28, 2005 | 07:43 PM
frederic's Avatar
frederic
Pull out the dipstick and look at the fluid. It shouldn't be dark. If it is, it needs to be changed at a minimum, and it's likely that something is toast. The fluid shouldn't burn.
There is a filter in there that if it is plugged up, it will reduce pressure and result in the tranny not holding tightly, but you can't really tell that without tearing the pan off.
Old Oct 28, 2005 | 10:32 PM
ssgnai's Avatar
ssgnai
As part of purchasing a new to me vehicle, I'd change all the fluids - helps me get to know the beast. Is the transmission fluid/pan/filter a DIY item?
Thanks
Old Oct 28, 2005 | 11:12 PM
pfogle's Avatar
pfogle
Yes, it sounds like it's in need of a filter and fresh fluid. It's pretty simple to do.
Old Oct 29, 2005 | 08:18 AM
frederic's Avatar
frederic
It's a DIY item. Enjoy lying on your back
Old Oct 29, 2005 | 07:21 PM
dust3's Avatar
dust3
And getting covered in tranny fluid. The first fluid change I ever do always includes welding in a drain bung or an aftermarket pan with one.
Old Oct 29, 2005 | 07:51 PM
Popa Tim's Avatar
Popa Tim
Covered??? Naw, just get one of the huge underbed plastic storage totes from Walmart for $5. It makes a GREAT Oil/Tranny fluid catch pan!!!
I DO like the drain plug idea though!!!
mrseventhree
Feb 11, 2015 09:11 PM
tguil
2009 - 2014 F150
Oct 17, 2011 08:34 PM
bill777
13
Nov 30, 2007 12:44 PM
lazzy8
1983 - 2012 Ranger & B-Series
Feb 17, 2007 04:11 PM
