Sponsored by: Real Truck
Tires: load range E...?
Old Oct 28, 2005 | 05:33 PM
joeyroe's Avatar
joeyroe
Question Tires: load range E...?
I have a 2005 F250 4x4 Deisel. I want to put some bigger tires on my 17" rims, but the tires have to be strong enough to support a 24' travel trailer.
Does anyone know who sells all-terrain or mud tires (load range E) that will fit a 17" rim...? I'm looking for about 33" tires or something close.
Thank You.
Old Oct 28, 2005 | 06:00 PM
Mustang42's Avatar
Mustang42
I don't know if any tires that big in a load E. I would look at the actual load capabilities of the tire first before I looked at the letter rating of the tire. There are many D rated tires that have more than enough rating to carry your trailer.
Old Oct 28, 2005 | 07:29 PM
Deaver's Avatar
Deaver
Mustang is correct
The "D" and "E" ratings are actually an old carry over for tire rating from the bias ply days. "D" meant that the tire had 8 plies and "E" was for 10 ply. With the currant technology, a more important factor is the weight capability of a given tire. If you look at BF Goodrich's site under specs. They will advise the weight load capacities for each size
Example
BFG All Terrain - LT265/70R17 is rated at 2470 lbs@50 PSI
BFG All Terrain - LT285/70R17 is rated at 3195 lbs @ 65 PSI
More info for All Terrains: http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
BFG - Mud Terrain info: http://www.bfgoodrichtires.com/asset...rain_ta_km.pdf
Other Mfg'rs provide similar info on their sites
Old Oct 28, 2005 | 08:10 PM
pumpdriver20's Avatar
pumpdriver20
Nitto Terra Grapplers are available in an "E" range.
Old Oct 28, 2005 | 08:59 PM
bandaman's Avatar
bandaman
Toyo Open Country A/T has a 285/70R17 (33X11.50R17) D Range 3195 lbs at 65 psi. They also have a 295/70R17 E Range Open Country M/T coming out, but who knows when....
Old Oct 28, 2005 | 10:31 PM
kabcpapc's Avatar
kabcpapc
Interco Tire Company has the TrXus MTs in a 33x12.50R17E rated at 3085 lbs. at 65 psi and a 35x12.50R17E rated at 3640 lbs. at 65 psi.
http://www.intercotire.com/site35.php
I have the 35x12.50R17E mounted on 17x10 Eagle Alloys series 114 on my 2002 F350 7.3L PSD 4x4 CC SB SRW. So far I am pleased with the way they ride and handle. Only have 7000 miles on the tires but they look to be wearing good.
Old Oct 29, 2005 | 05:53 AM
Sailsonly's Avatar
Sailsonly
If you are really concerned about load capacity make sure you have tires filled to the proper psi when cold, 5-10 psi below max. inflation reduces the capacity by alot can't remember the exact percentage, I'm sure somebody on site knows.
