Adding Cargo Light to F/G Tonneau Cover
I installed a tap and go light from Walmart on the underside of mine. I used velcro to hold it on and thus far it has worked exactly as I wanted. Something else I will end up doing once it warms up is to run an accessory outlet back there. Walmart sells a magnetic light that plugs into this. This way I can obtain much more light and stick the light wherever I want it. Just two thoughts for you.
Griz
Griz
