Rear Wiper Blues
Read through most of the threads regarding the problems with the rear wiper on Expy's. Mine is a '99 XLT. The rear wiper died like so many others....more and more intermintant and then just died.
A while back I checked the two relays under the hood next to the larger fuse/relay panel and they were clicking like they should. Finally purchased a replacement motor and went after it tonight. Replaced the motor and still no workie!!!! %#$&*# So I start to check things out and now I'm not hearing the relays click. I pulled 'em out and tested them; they work just fine.
Is there a way to check the switch in the TS arm? All other functions of the TS arm work (WS wiper, rear squirter, TSs, etc). I also checked all fuses with a light. I didn't find any that were blown, however I did come across several in a column that were not energized at all. Is that normal? Unfortunetly I don't have a manual that tells me what the fuses are.
What else can I check to further troubleshoot this circuit? I have the auto parts store getting me another reman motor, but I'd like some input.
Thanks in advance!
p.s. After this one, we'll discuss the "low washer fluid" indicator thats always on, the ABS indicator intermintantly coming on, and the odometer fading and cutting out occasionally. Don't get me wrong, I (and my family) love our Expy and I've been a Ford driver since about '92!
check this thread --- dakota_viking did a good job and has good pics
Assuming it is, I'd start looking at the switch that prevents the wiper from working if the door is open. I think there are two, one on the glass latch and one on the door latch.
Next question: Is the TS and it's functions connected through some sort of "power control module" that might possibly be bad.?
