4x4 driveability problem
Snow is coming and I have plowing to do. When changing my front brakes and calipers earlier this week, I noticed the vacuum line to the ESOF was dry-rotted on both the nipple (at the knuckle) end and the end that attached to the hose adapter assembly on the frame. That explained why I did not have 4x4 when I tested it a week earlier in the rocks. I didn't know about locking the hubs then, but thanks to FTE, I do now.
Anyway I clipped the dry rotted hose at both ends and reattached the ESOF. Tonight, I shifted in the 4x4 high, felt it kick in, and felt a bit of resistance, thinking it was simply those extra tires that were being driven, but was glad my little nip and tuck trick worked. Overall it drove OK. About a mile late, I drove into a parking lot, began to turn left, and I thought my wheels were coming off! I felt an awful grinding-line vibration coming from the left wheel and it almost felt like I was skidding, though I assume that was just an effect. After taking it out of 4x4, no problem turning. So I did some testing. I disconnect the vacuum hoses, plugged them with small bolts, and went out to try it again. When the hubs are in AUTO, I kick into 4x4 and no problem. But when the hubs are in LOCK, I get that same grinding feeling while turning, both left and right. Only while turning - it feels OK when i am going straight.
What say ye?
I'm not familiar with your fancy shmancy 4x4 push button hoopajoob jobber, but it sounds like you described what happens when an older 4x4 locks in his hubs, Tcase and proceeds to mall crawl. When your turning, your U joints are binding up, becuase you have no tire scrub on pavement. Same for when straight line driving, no tire scrub bewteen the different speeds of your front and rear end. Then when taken out of 4x4, the binding goes away becuase nothing is locked in and can turn independently
Help any?
I lived off Great Neck Road for a while, and over on Shore Drive for a while during my Navy tour. I had a 4x2 Chevy inline 6 back then with bias ply tires. During the blizzard of '78, I took that truck through a corn field of deep snow in order to get around a bunch of cars that were stuck. I got to my ship (in Little Creek) with only a couple of minutes to spare before they pulled the gangplank. Great memories, Va. Beach!
Wait. . .Blizzard of '78? A real blizzard, or just a few inches of snow?
