Sponsored by: Real Truck
Front Brake Bracket Slide Pins
Old Oct 27, 2005 | 02:35 PM
MILL's Avatar
MILL
Is There A Way To Free Up The Slide Pins On The Bracket That The Caliper Attaches To? I Used Some High Temp Grease To Lube Them And They Still Froze Up And Its About $80 For A New Bracket From Ford
Old Oct 27, 2005 | 03:48 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Heat... lots of it.
But you'll need new pins and who knows what the bushings in the bracket look like? Chances are they are shot too...
Auto parts places sell something called a "loaded pair" - a pair of calipers, pads, and the brackets that bolt to the spindle. You could do that, and replace the whole setup, or maybe check if the parts place can get the bracket itself - it's sure to be cheaper than Ford
On edit: I know NAPA sells loaded pairs.
Old Oct 27, 2005 | 04:23 PM
FortyFords's Avatar
FortyFords
Heat but not lots of it.
You should not over heat any brake parts or steering components.
Always use dielectric grease on the pins after you get them apart.
were they corroded,that means the rubber seals were leaking.
Change them an get new bracket with new pins.
Just my opinion
Rich
Old Oct 27, 2005 | 04:39 PM
krewat's Avatar
krewat
True, I was being sarcastic...
Old Oct 27, 2005 | 05:04 PM
99_EB_EXPY's Avatar
99_EB_EXPY
So the poor guy goes right out and cherry reds his brackets on your advice.....
Now that's real helpful!
Old Oct 27, 2005 | 08:11 PM
FortyFords's Avatar
FortyFords
Art ,I knew that ! was just pickin on ya!
Rcih
Old Oct 27, 2005 | 09:02 PM
WuShock's Avatar
WuShock
What good does using Dielectric grease on brake caliper pins?
Last weekend I purchased new slide pins and bushings. I think they were around $8 a side and took about ten minutes each to replace.
Old Oct 27, 2005 | 09:07 PM
vtmdsm25's Avatar
vtmdsm25
Loaded pairs
Heat... lots of it.
I just replaced these items on my 99 F250. They are also called "loaded calipers". I've always bought them from CarQuest.
Old Oct 27, 2005 | 09:14 PM
krewat's Avatar
krewat
And they came with the bracket?
Old Oct 28, 2005 | 07:03 AM
FortyFords's Avatar
FortyFords
If you read the description on the tube of grease you will see that this what it is used for also.
It repells water stops corrosion, plus lubes the pins.
At least thats whats on the stuff I use from FORD.
Rich
Old Oct 28, 2005 | 08:00 AM
krewat's Avatar
krewat
Rich
Is dialectric grease suitable for hi temps?
Old Oct 28, 2005 | 11:14 AM
pachangalpina's Avatar
pachangalpina
What do you consider hi temps? Caliper piston seals are generally rated at 320 and DOT 3 brake fluids have a saturated boiling point of 284 while DOT 4 is 311. Not sure what the temp rating is on the dielectric grease but I would think it would be more than adequate for this application.
Old Oct 28, 2005 | 01:09 PM
vtmdsm25's Avatar
vtmdsm25
Loaded calipers
Yes, all I did was pull the two bracket bolts, disconnect the brake lines, pull the old caliper off, put the new caliper (with bracket) on, put the two bolts back, reconnect the brake line, then bleed the line. Piece of cake. I almost never reuse the rotors - I always put on new ones. That's because I have two grandkids, and the brakes are the front line of defense for accident avoidance. I'm also real picky about tire quality.
Old Oct 28, 2005 | 01:26 PM
Steve_250's Avatar
Steve_250
Do the ART rotors come with everything you need to replace rotor, calipers, pins, pads, etc?
Or is it another $300 per axle?
Old Oct 28, 2005 | 02:58 PM
krewat's Avatar
krewat
Good advice.
