Sponsored by: Real Truck
05 Head Lights Upgrade
Old Oct 27, 2005 | 02:23 PM
escdoc88's Avatar
escdoc88
Anyone upgrade the bulbs for the 05 F350,I have read the previos posts on older trucks with changes in the bulbs, wiring harness upgrades and the bright box. The 05 uses a different bulb according to the Sylvinia website listed:http://www.sylvania.com/ConsumerProd...RG-Results.htm. The headlamp is H13XV XtraVision Halogen Upgrade: Up to 20% Brighter and the foglamps are 9145ST Silverstar High Performance Lighting: the whitest and brightest Halogen. Has anyone changed to the aftermarket bulbs? Does the 05 have a heavier wiring harness than prevous models? Does an after market heavier wiring harness (http://www.suvlights.com/) in the 05 improve lighting like the older ford SDs? Anyone used the bright box in an 05 that keeps the low beams on when the high beams are turned on http://www.genosgarage.com/CoastalData/showdetl.cfm?&DID=30&User_ID=574150&st=9677&st2=59 711217&st3=-54643740&Product_ID=1723&CATID=2.
