well, the easiest thing to do would be just to wire them into a switched circuit so they come on anytime your key is on the on position. some true daytime running lights will turn themselves off when you are parked with the e-brake on, and that would just be more of a hassle.
wiring them into the ign wouldnt be a bad idea. Anouther idea is to just wire them into a toggle switch. That way you can turn them on and off whenever you want. GL
Thanks. This place is great! I just joined and look forward to all this great info.
I like the switch idea. I want to have the fog lights on during daytime trips on two lane highways. I've seen other f250's and Excursions with the fog lamps on when the headlights were off.
your welcome, just let us know if you need anything eles. Dont be afraid to chim in if you see a post that you know a little about. We can always use different opions. GL
I bought a $10 daytime running light kit from National auto stores where light comes on with a relay when ignition wire has power. I believe you could just wire the fog lights instead of the low beam.
