frame questions
Old Oct 26, 2005 | 07:48 PM
grabberblue's Avatar
grabberblue
frame questions
does the 2wd frame have the same shape as the 4wd frame for the 73-79 f-150
Old Oct 26, 2005 | 10:12 PM
teds74ford's Avatar
teds74ford
I have been trying to find that out. I think the rail shape is the same but the mount points are different
Old Oct 26, 2005 | 11:20 PM
pokerpuller's Avatar
pokerpuller
its the same up to the front of the cab, but forwards of that its radically different. the engine crossmember is a different shape and in a different place, and the steering box mounts in front of the crossmember on the 4wd, as opposed to behind the crossmember in the 2wd. i remember being told that you can not take the crossmember off a 4wd and put it on a 2wd, but i don't remember why.
-kit
Old Oct 28, 2005 | 11:28 AM
bjhous2's Avatar
bjhous2
2wd vs 4wd frame
I am doing this conversion right now putting 79 4wd drivetrain under a 76 2wd frame.
None of the holes have been where I thought that they would be so far including spring towers, shock mounts, trac bar mount, steering box mount, t-case crossmember mount.
The 4wd engine crossmember is welded in I haven't decided what to do with that yet I have 351M from my 79 the 2wd has a working 302 in it right now.
Much of the drivers side inner frame rail is boxed where the coil towers, trac-bar, and steering box mount all of this I will have to custom fabricate.
Old Oct 28, 2005 | 11:46 AM
highboy1975's Avatar
highboy1975
why not just switch the entire frame?
Old Oct 28, 2005 | 12:20 PM
bjhous2's Avatar
bjhous2
Because the body on the 2wd frame was in much better shape (North Carolina Truck) and my old 79 frame had a 3" body lift which I didn't want to use anymore and alot of the frame on my 79 has been molested/abused/bent etc..
