What is better, weld the spiders or the side gears?
It's done! I took it for a test drive a little while ago. It works great. I don't know why so many people warn you about driving with a spooled or welded front. It's is harder to steer but it still steers OK. I turned sharp corners OK too. I would not consider driving very fast locked though and never use it locked on pavment. But for off road use it is fine. I also tried it with just one hub locked. When only one hub is locked it turns easier but pulls a bit, if you get on the throttle it pulls alot to the locked side. But with power steering it is very controlable. Thanks!
I hate to post this but I busted my rear drivers side axle today. I haven't pulled her apart but there was a pop and she started to drive real funny. Got home and jacked up the rear and the drivers side rotates almost a full 360, then she comes up tight, with a little force she cams over. I assume its the axle cause if it was in the case I figure a chunk would catch between the gears and jam things up. I drove it the 12 miles home. With the trany in neutral the passenger side rotates smooth. I'm lucky and I have a spare 9 inch out of a f100, so I can swap out the axles and diff. The Q is should I keep running the welded rear? I broke this with 33x12.50x15 TSL's. Maybe welded rears shouldn't be run dailey on the street? O well if it aint broke your not running it hard enough.
I've heard of the full floater idea, but after driving home today on one axle i wouldn't sugest it. torque steer was horrible. Every time I stepped on it it felt like she wanted to crab walk on me. Yeah I will swap out the diff and axles, probaly put cutting brakes on the rear and weld my front diff. I would only use my front end offroad and there will be alot more give than on pavement. that way I can keep traction with tires on the ground. and still have a open dif in the rear for street drivng. Tire wear is horrible with a welded rear, about 3 times faster than the front. Traction is awesome offroad though. With cutting brakes on the rear, when one tire looses traction and the tire with traction stops, I can lock the spinning tire up and send the power to the one with traction. Welding the front diff will keep the fronts turning all the time. Tight turns I can unlock a hub. Seems a good way to go. And yes I know cutting brakes are illegal on the street. Now ask me if I care.
#29
kopenjagfer, dont reweld the swapped in axle. just leave it open and save up for something a lil stronger casue it'll just do it again!
tire wear is a huge issue and the bigger the tires the more wear (or it seems like)
if you drive a newer truck (after 96) dont do it! you will run into too many problems with all the 'new improved' technology. trucks just aren't being built like they used to be (IE the superdutys use a pretty weak unit bearing hub design).
-cutts-
-cutts-
#30
hey captain, have someone look at your front driveshaft when you roll it forward a few feet in 2wd. If the shaft turns, chances are it just disengages at the transfer case, and yes you would have driveability problems, you'd turn, and it would try to go straight. If your hubs actually do disconnect from the shafts and your diff doesn't turn when in 2wd, you shouldn't have a problem doing that.
