i have a 02 expedition 4.6 65,000 miles. i changed the plug and the coil my obdII still reades p0303.i dont no what else to do.also is # 3 on passenger side need to be sure. i also switched back to motorcraft plugs.my code reader has that code p0303 and pending, i guess thje next cycle.
Reason: forgot
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Yes the #3 cylinder is on the passenger side (right bank). Ususally I would think a bad coil would cause this problem but it sounds like you have already swapped it out. You could try switching the coils on the #3 and #4 cylinders and see if it will start the miss on #4 instead. That would tell you that the #3 coil (the one that you moved over to #4) is bad. Good luck!
