FULL TIME 4WHEEL DRIVE QUESTION
Old Apr 29, 2002 | 11:54 PM
Mil1ion's Avatar
Mil1ion
Old May 1, 2002 | 02:03 PM
8ACHEVY's Avatar
8ACHEVY
Ok, I have a 1974-1976 ford stepside. It is full time four wheel drive. CORECT IF I AM WRONG, BUT THE ONLY WAY TO TAKE IT OUT OF FOUR WHEEL DRIVE IS TO DISCONNECT THE FRONT DRIVE SHAFT RIGHT??
ANOTHER QUESTION THAT I HAVE ABOUT IT IS, DOES THE FOUR WHEEL DRIVE KICK OUT AT A CERTAIN SPEED, OR IS IT IN ALL OF THE TIME.
KIND OF OFF THE TOPIC, BUT ABOUT HOW MUCH WOULD A CONVERSION KIT COST TO CHANGE MY TRUCK FROM FULL TIME FOUR WHEEL DRIVE TO HAVING LOCK OUTS ON IT.
ALL HELP WILL BE GREATLY APPRECIATED.
THANKS JEREMY
Old May 1, 2002 | 03:42 PM
sideout2's Avatar
sideout2
You can not take the front driveshaft out. The NP208 tranfer case switches between the front a rear depending on whitch one has traction. When you put it in low or high lock then both front and rear have power full time.
Old May 1, 2002 | 03:49 PM
proford460's Avatar
proford460
The NP203 transfer case is similiar to an open differential it will send the power to the easiest to spin driveshaft. Pulling the lever makes both drives spin. if you do remove the front shaft you have to keep transfer case locked in Warn makes a convesion kit but would recommend a donor veh with the newer NP205 transfercase
Old May 1, 2002 | 04:05 PM
Mil1ion's Avatar
Mil1ion
[updated:LAST EDITED ON 01-May-02 AT 05:09 PM (EST)]>Ok, I have a 1974-1976 ford stepside. It is full time four
>SHAFT RIGHT??
>THE TIME.
Hi Jeremy, I highlighted your post because it was written all caps and I CAN'T read it if it is posted in all caps.
Maybe, you could post in lower case instead, please!
I saw questions like this on another site.
I think it was here.
http://4wheeldrive.about.com/cs/techforbroncos/
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green]Do You Need To Decode Your 78 Truck Data Plate?
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
[font color=green]Please Feel Free To Visit My Website.[/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V [/font]
Old May 1, 2002 | 05:19 PM
Jermafenser's Avatar
Jermafenser
Why do people always convert from NP203 to NP205?
Old May 1, 2002 | 06:27 PM
tomk89xlt's Avatar
tomk89xlt
np203 = full time
np205 = part time
np203 = chain driven
np205 = gear driven
np 205 is considered indestructible
Old May 1, 2002 | 07:45 PM
hawkrod's Avatar
hawkrod
i respectfully disagree, it is not indestructable! let it fill with water and wash out they oil while fording a creek and then drive for a few months and they will get a little noisy as the water leaks out. then drive for another year or so on the oil film that is left and then if you are pulling really hard up a hill with a nasty big block and one tire slips and then grabs you may actually do some damage (but probably not much!). finding replacement parts will be a problem as no one stocks them BECAUSE THEY ARE INDESTRUCTABLE! hawkrod (oh, and yes, the used one i bought out of the paper is till doing fine with over 200K since i installed it. thanks for asking!)
Old May 1, 2002 | 08:34 PM
8ACHEVY's Avatar
8ACHEVY
Here you go. I changes everything to lower case I hope this helps.
Ok, I have a 1974-1976 ford stepside. It is full time four wheel drive. Correct me if I am wrong, but the only way to take it out of Four Wheel drive is to disconnect the front drive shaft right?
Another Question that I have is about it is, does the four wheel drive kick out at a certain speed, or is it in all of the time.
Kind of off the topic, but about how much would a conversion kit cost to change my truck from full time four wheel drive to having lock outs on it.
All help will be greatly appreciated.
Thanks Jeremy.
Old May 2, 2002 | 07:37 AM
dzjammer's Avatar
dzjammer
The 205 is not indestructible. I have one that I believe the front driveshaft dropped and punched through the back of the case. The previous owner simply unbolted the front shaft and kept on running. I guess it wasn't really the cases fault. I bought it and drove it home 50 miles like this and then discovered that there also was no oil in the rear end. The 9" still lasted 35k till it gave up.
But the real question is the conversion, you have a case that is full time. If you want to test it, unbolt the front shaft and see what happens, it won't hurt anything. If it all still works, then go get some Warn lockouts and put them in. I would avoid Mile Marker, they seem pretty cheap inside to me.
Old May 2, 2002 | 01:13 PM
DantheMan's Avatar
DantheMan
Jeremy,
Don't change it, I've got full-time four wheel drive on my truck and I love it. Sure you can't smoke the tires, but it will never slip on wet grass, spin you truck around on ice because the pavement was too dry to lock in the T-case. A friend changed it overthe hubs and then changed it back because the truck was helpless. It doesn't effect gas milage that much. Wait till it drops, then change.
Old May 2, 2002 | 07:39 PM
8ACHEVY's Avatar
8ACHEVY
Yeah, I know that you say wait until the gas miliage drops, but I am only getting 6 thats right I repeat 6 miles to the gallon, and the sad thing is I am only running 55-60mph and have 33 inch tires, and I have a 390. With a holly carb. One of my buddies is only getting 6 miles to the gallon, and he has a 429 and 36 inch tires.
So any Ideas of about how much a conversion kit would cost, forsay down the road.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
