460- 79 vs 85
Old Oct 25, 2005 | 08:44 PM
neals's Avatar
neals
460- 79 vs 85
I've got a 460 from a 1979 1/2 ford and am putting it in a 1985 ford 3/4 4x4. The 78 engine has a balance weight on the front of the crank. Will my flywheel and harmonic balancer from the 85 work? The 79 is externally balanced and the 85 is internally balanced; isnt that right?Thanks, david
Old Oct 26, 2005 | 01:59 AM
monsterbaby's Avatar
monsterbaby
the balancer will work but the flywheel won't. on an external balanced engine the weight is the hatched weight on the spacer, the balancers are both zero balanced but the flywheel/flexplates have the counter wieght attached to them so not interchangable.
