1948-1960: 1949/1950 VIN # Cut off
#991
A few weeks ago I purchased a 51 F1 from a fellow member Brit_Wheels_Fan and I found that he never listed the info here. I actually know the info on the truck, but I wanted to post it so that it can be included in this 'data base' of sorts.
Serial number F1R1CH21718
F1= half ton short bed
R1= 239 cu in V8 (flathead)
CH= Chicago Plant
21718= Consecutive unit number
Firewall stamping CH D 16D 34J
CH= Chicago Plant
D- Color - Alpine Blue
16D= Production Date April 16
34J= Internal plant code
CH= Chicago Plant
CH= Chicago Plant
#992
#993
#994
Just for the sake of curiosity, I will start a new thread for the 51-52 trucks and I will set up a database to see the comparisons. I'll go back through this thread and enter the 51-52's already posted.
#995
assistance with VIN / serial number
I just purchased a 1948 frame... or maybe not. Can someone please ID the number I found on the passenger's side top frame rail
93RC 435850
from my research, 93RC indicates a 1949 - not a 48
Can anyone confirm? He also said it originally had a flathead V8
thank you
dave
93RC 435850
thank you
dave
#996
I believe if you look closer you'll see the number starts with 98RC, not 93. The beginning 9 was used in 49 and 50. 8R indicates 239 V8, C is half ton F1, and with a unit number that high, it would be a 1950 model.
#997
#998
I guess I should have mentioned 93 was not an option. The serial strings started with either 97H for 6 cylinder, or 98R for 49/50 V8 F1's.
#999
Hi guys. New to the forum. I just pulled a 49 or 50 flat bed F1 out of the woods in amazing condition considering it was parked in the woods and sunk in the dirt since before 1964.
Here is the tag info I found. I would appreciate if you could help me decode all of this.
Vin tag on pass side of firewall reads *98RC*372615*KC
Firewall stampings read 2 KC 25D277
Glove box tag reads 98RC 33 72615 (note, the first 3 is very faint and hard to read).
The truck apprears to be a F1, V8, stick shift, with Ford OEM stake bed. Originally painted Red. It has the pickup style running boards (they are longer with holes that would attach to the rear fenders) but the stake bed is definely a Ford stake bed because it has the Ford Logo imprinted on the back. The remaining wood and stake bed are the same color as the interior of the body (red) but I am wondering if the numbers show this was originally a pickup. Could the pickup bed have been changed to a stake bed at the dealership before delivery? Please let me know what you think.
#1000
Vin tag on pass side of firewall reads *98RC*372615*KC That's actually a Patent Data Plate, and not a VIN tag.
I say that is the serial number for the cab because the only valid serial number for the truck is stamped into the top right frame rail just ahead of the motor mount. If you can verify that number matches the two you've found, *98RC*372615*, then that is the correct number for your entire truck.
Here's where I found my frame stamp.
#1001
Thanks for the info. I think you are right about the first "3". I did not realize those numbers were so close to each other. After looking at the pictures again, it does seem to be a misprint in the tag.
I can't get to the frame yet as the hood is stuck in position so I am oiling the hinge points to try and get it to move. My bet is the frame number will match. The truck was parked in the woods around 1960-64 and was never touched from that point forward except for "some kid" breaking the windows out of it (that kid is the guy in the yellow shirt in the picture....I jokingly told his mom that he would not be getting away with it as I would be invoiceing him for the cost of the new glass...LOL).
#1002
Joe has the serial number.
Firewall tells:
2 - Vermillion Red
KC - Kansas City plant
25D - 25 April 1950 assembly date
277 - anybody's guess (in-house numbering system)
They made F1 flatbeds, but the length of your running boards looks like this was after-market modification. (Those would have attached to the pickup fenders - flatbed running boards are much shorter and stop at the back of the cab)
Nothing from the factory indicates what it would have been originally. Enjoy!
Firewall tells:
2 - Vermillion Red
#1004
