1948-1960: 1949/1950 VIN # Cut off
  #991
Old 02-09-2015, 04:31 AM
DoWhat
DoWhat is offline
DoWhat is starting off with a positive reputation.
Originally Posted by mtflat View Post
I have 2 later than yours:
One 508xxx in MN, the other 510xxx in TX
But you're close and you do have the latest firewall stamping - thanks for sharing. It helps to figure out where the 50/51 split took place.
1) What is the decode of my firewall please?
2) Also I heard there is an interest in the rear windshield. The metal opening is 27.5 x 9.25 in. But I don't know if that is small or big.
Thanks
  #992
Old 02-09-2015, 08:14 AM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Originally Posted by DoWhat View Post
1) 1950 F1
2) 98RC 508032 CH
3) flat bed sides and front, script tailgate
4) no clue
5) no clue
6) column shift
7) C4314L76B ?
I want to know if I have the very last 48-50 model still in existance.
CH - Chicago assembly plant (if you look closer I bet your second character is H)
3 is the code for Black
14L was the date it was assembled - 14 November
76B is in-house encoding specific to each plant. We don't know.
27.5" sounds like a small back window - the large one reaches from almost cab corner to cab corner and was used 51/52 although some plants might have used them for late 50s. It's one of the things we're trying to sort out. Height was the same for both. Thanks for your help
  #993
Old 05-23-2015, 08:59 AM
harleymsn's Avatar
harleymsn
harleymsn is online now
harleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to behold
A few weeks ago I purchased a 51 F1 from a fellow member Brit_Wheels_Fan and I found that he never listed the info here. I actually know the info on the truck, but I wanted to post it so that it can be included in this 'data base' of sorts.
Serial number F1R1CH21718
F1= half ton short bed
R1= 239 cu in V8 (flathead)
CH= Chicago Plant
21718= Consecutive unit number
Firewall stamping CH D 16D 34J
CH= Chicago Plant
D- Color - Alpine Blue
16D= Production Date April 16
34J= Internal plant code
  #994
Old 05-23-2015, 12:08 PM
mtflat
mtflat is offline
Maybe it would be good to start a 51/52 vin thread? I'll let somebody else keep that data - I'd love to know if each plant ran their own serial string..... because it wasn't collective like on 48-50's
  #995
Old 05-23-2015, 01:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
The 51/52 serial #'s really don't need any further dissection to get the info, and the changes were pretty minor. I believe each plant did their own numbers, I can't recall seeing a number higher than about 35000.
  #996
Old 05-23-2015, 03:15 PM
harleymsn's Avatar
harleymsn
I'd be curious about the serial numbers. LMC, who I think is wrong, claims that some early 51's (prior to Sept. 15,1951) were given the 49-50 serial numbers starting with 98. My truck tends to dispel that since it was built in April of 51 and starts with the F1R1.... I think that the Data Plate change may have been Sept.
Just for the sake of curiosity, I will start a new thread for the 51-52 trucks and I will set up a database to see the comparisons. I'll go back through this thread and enter the 51-52's already posted.
  #997
Old 05-31-2015, 10:07 AM
daveheld
daveheld is offline
daveheld is starting off with a positive reputation.
assistance with VIN / serial number
I just purchased a 1948 frame... or maybe not. Can someone please ID the number I found on the passenger's side top frame rail
93RC 435850
from my research, 93RC indicates a 1949 - not a 48
Can anyone confirm? He also said it originally had a flathead V8
thank you
dave
  #998
Old 05-31-2015, 01:05 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
93RC 435850
thank you
dave
I believe if you look closer you'll see the number starts with 98RC, not 93. The beginning 9 was used in 49 and 50. 8R indicates 239 V8, C is half ton F1, and with a unit number that high, it would be a 1950 model.
  #999
Old 05-31-2015, 03:36 PM
daveheld
daveheld is offline
thank you very much for the info... I'll take another look at the frame and check for a 98 vs. 93
I'm not too concerned if it's a 48/49 or 50 - just nice to know
thanks again
dave
  #1000
Old 05-31-2015, 06:25 PM
52 Merc's Avatar
52 Merc
thanks again
dave
I guess I should have mentioned 93 was not an option. The serial strings started with either 97H for 6 cylinder, or 98R for 49/50 V8 F1's.
  #1001
Old 06-23-2015, 12:22 PM
myF1fund
myF1fund is offline
myF1fund is starting off with a positive reputation.
Hi guys. New to the forum. I just pulled a 49 or 50 flat bed F1 out of the woods in amazing condition considering it was parked in the woods and sunk in the dirt since before 1964.
Here is the tag info I found. I would appreciate if you could help me decode all of this.
Vin tag on pass side of firewall reads *98RC*372615*KC
Firewall stampings read 2 KC 25D277
Glove box tag reads 98RC 33 72615 (note, the first 3 is very faint and hard to read).
The truck apprears to be a F1, V8, stick shift, with Ford OEM stake bed. Originally painted Red. It has the pickup style running boards (they are longer with holes that would attach to the rear fenders) but the stake bed is definely a Ford stake bed because it has the Ford Logo imprinted on the back. The remaining wood and stake bed are the same color as the interior of the body (red) but I am wondering if the numbers show this was originally a pickup. Could the pickup bed have been changed to a stake bed at the dealership before delivery? Please let me know what you think.
  #1002
Old 06-23-2015, 01:57 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant future
Vin tag on pass side of firewall reads *98RC*372615*KC That's actually a Patent Data Plate, and not a VIN tag.
I think that first "3" is probably a "goof" by the stamper, who then redid it correctly. Other than that, your two numbers match. I suspect it has something to do with the punch used. The truck serial number FOR THAT CAB is 372615. The KC is for the Kansas City plant where it was built. The 98 indicates a 1950 as that serial number is higher than the 49 cutoff (I think)... experts should be along any minute to clarify my gibberish.
I say that is the serial number for the cab because the only valid serial number for the truck is stamped into the top right frame rail just ahead of the motor mount. If you can verify that number matches the two you've found, *98RC*372615*, then that is the correct number for your entire truck.
Here's where I found my frame stamp.
  #1003
Old 06-23-2015, 05:45 PM
myF1fund
myF1fund is offline
Thanks for the info. I think you are right about the first "3". I did not realize those numbers were so close to each other. After looking at the pictures again, it does seem to be a misprint in the tag.
I can't get to the frame yet as the hood is stuck in position so I am oiling the hinge points to try and get it to move. My bet is the frame number will match. The truck was parked in the woods around 1960-64 and was never touched from that point forward except for "some kid" breaking the windows out of it (that kid is the guy in the yellow shirt in the picture....I jokingly told his mom that he would not be getting away with it as I would be invoiceing him for the cost of the new glass...LOL).
  #1004
Old 06-24-2015, 12:23 AM
mtflat
mtflat is offline
Joe has the serial number.
Firewall tells:
2 - Vermillion Red
KC - Kansas City plant
25D - 25 April 1950 assembly date
277 - anybody's guess (in-house numbering system)
They made F1 flatbeds, but the length of your running boards looks like this was after-market modification. (Those would have attached to the pickup fenders - flatbed running boards are much shorter and stop at the back of the cab)
Nothing from the factory indicates what it would have been originally. Enjoy!
  #1005
Old 07-02-2015, 06:36 PM
chrislynn5
chrislynn5 is offline
chrislynn5 is starting off with a positive reputation.
please decode
Need some assistance to decode my VIN: 87HT29396
Believe 1948 F-6?
It has wood bed, dualie. Did they make a F1 dualie? Thanx.
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
