1948-1960: 1949/1950 VIN # Cut off
Old 03-15-2017, 09:51 PM
Navy Dad's Avatar
Navy Dad
Navy Dad is offline
As you suspect, I hae no stamped numbers in the cowl. Also the truck has what appears to be the original F6 on the cab. If I get some picks of the spring pack, would that be an indication of F6 or F5?
I also have a line on what is said to be a 52 F5, but has the 48-50 grill. I am going to pick it up for parts, but will not use most of it. I will get numers from it this weekend.
  #1097
Old 03-15-2017, 10:00 PM
Navy Dad's Avatar
Navy Dad
Navy Dad is offline
Here are some close ups of the F6 badging and interior.
  #1098
Old 03-15-2017, 11:09 PM
mtflat's Avatar
mtflat
mtflat is offline
It looks like an F6 to me. I'll look up the info on spring packs - it might id things.
This wouldn't be the first truck that was mis-stamped. Couple that with the fact that Ford made running line changes, anything is possible.
As one example, when they first started in 48, there was no separate designation for F2's. They were stamped the same as F3's until they produced something like 110,000 units (if my memory is working right).
  #1099
Old 03-19-2017, 03:55 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Earlier in this thread we decided that 48 cabs, at least the earlier ones, have three vertical ribs in the back wall. The F-5 / F-6 has the smooth back wall. Hmm...
  #1100
Old 03-19-2017, 04:15 PM
Merimar1's Avatar
Merimar1
Merimar1 is offline
Here's my ser #
Great idea!
1950 F-1
98RC448495. KC
Flat bed
3 speed floor shift
Second owner all original matching numbers at the frame,firewall and glove box. I have copy of the original title as well. This truck is original.
Also stamped in the firewall in large 1" stamps is: M. KC. 9J160. I'm not sure how to decode that number. I read on another post that it was paint code,plant and date of manufacture.
I previously owned a late 50 F-1 with raised panel,no firewall stampings, three on the tree ser # 98RC487348 only on glove box. Cannot verify the bed originality.
  #1101
Old 03-19-2017, 05:09 PM
bgbdbrwn's Avatar
bgbdbrwn
bgbdbrwn is offline
Decode
Can anyone tell me what this cab is my father inlaw has. It looks to maybe have been a fire truck. Theres holes on both sides top of the a pillar. And holes in the center of the roof just behind the windshield line. Im guessing from what ive read its a 49 or 50 F6 239 V8 built in chicago. The patent plate on passenger firewall reads
98RTH*308xxx* Branch CH
just below the cowel on the firewall just off center towards driver side this is stamped:
2 CH 24A 445.
would like to know what these all mean.
there is no tag in glove box. Lid was gone.
thanks for any info!
  #1102
Old 03-19-2017, 06:20 PM
mtflat's Avatar
mtflat
mtflat is offline
Actually Fred, the ribs seem to depend more on which supplier provided cabs for a given assembly plant.
Navy Dad, the spring packs on both F5 and F6 contained 11 up front and 12 in the back. Both could be ordered with overload packs and according tot he shop manual, even F4s could be ordered with the 11/12 setup - I have an F4 set up that way.
  #1103
Old 03-19-2017, 06:24 PM
mtflat's Avatar
mtflat
mtflat is offline
Originally Posted by Merimar1
Great idea!
1950 F-1
98RC448495. KC
Flat bed
3 speed floor shift
Your current 50 was/is the 239 flathead V8 produced in Kansas City. Firewall says it was M - Meadow Green; KC - Kansas City; 9J - September 9 assembly; 160 - vehicle down the line
Thanks for adding to the data base.
  #1104
Old 03-19-2017, 06:33 PM
mtflat's Avatar
mtflat
mtflat is offline
2 CH 24A 445.
9 - 49/50
8R - 239 flathead V8
TH - F6 two ton
308xxx
CH - Chicago
Firewall
2 - Vermillion Red
CH - Chicago assembly plant
24A - Jan 24 assembly date
445 - vehicle down the line
edited to clarify model years
  #1105
Old 03-19-2017, 07:06 PM
bgbdbrwn's Avatar
bgbdbrwn
bgbdbrwn is offline
Originally Posted by mtflat
9 - 40/50
TH - F6 two ton
308xxx
CH - Chicago
Firewall
2 - Vermillion Red
Think you meant 49/50 correct? And being suck a low number 308xxx its hard to tell if its a 49 or 50.
  #1106
Old 03-19-2017, 07:14 PM
bgbdbrwn's Avatar
bgbdbrwn
bgbdbrwn is offline
also is there a way ford might be able to tell where this vehicle was shipped to upon completion st the chicago plant?
  #1107
Old 03-19-2017, 07:23 PM
bgbdbrwn's Avatar
bgbdbrwn
bgbdbrwn is offline
and one more question lol. Im a right in thst the number on the plate would in fact be the VIN #/serial #
  #1108
Old 03-19-2017, 11:41 PM
mtflat's Avatar
mtflat
mtflat is offline
yes, 49/50 and no, January 24th would have been 1950. Ford was using the calendar year for model year with these new trucks and did so until Sept of 1951. Your truck is clearly a 50
there is no way to know where it shipped from Chicago that I know of. Ford burned all the records in/around 1967. Unless you found original registration or other owner records in your truck it will remain a mystery.
The serial number *98RTH 308xxx* was originally on the frame, data plate (firewall) and rating plate (glovebox door). It wasn't referred to as a VIN until the 60's.
  #1109
Old 03-20-2017, 08:08 AM
Merimar1's Avatar
Merimar1
Merimar1 is offline
Mtflat,
Thanks for breaking down my cowl stamping. I just looked at the copy of the original title and it shows it was sold on 9-9-50 to a guy in Akron, Colorado. Not sure how the State of Colorado registers but they show the sold date as the same date it was built. On the front side of the title it shows a typewritten date of 9-18-50. It also shows a lien date of 9-9-50. For those curious the guy paid $1205. And financed $816.00. The recorded weight was 3001#.
  #1110
Old 05-02-2017, 02:44 PM
yosemite98's Avatar
yosemite98
yosemite98 is offline
Registered as a 1950 Ford F1, Flathead V8, 3 speed non-synchro shift on floor
98RC 330095 Branch "BUF"
Numbers match on glove box
On firewall... hard to read, but maybe:
1 0 B F(or 7 or Z) 8 8 l J 1 The B F 8 8 is a guess... others are pretty clear
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
