engine swap
Old Oct 25, 2005 | 06:10 AM
Strokin' Ace's Avatar
Strokin' Ace
engine swap
I have a 2wd 78 f100 w/300 & 3spd manual. THe body & frame are pretty rough & the motor is excellent w/new rebuild. What years will this motor drop right into? I am looking for a truck with a great body & a bad motor. I will probably look for a c6 or 4spd. 2wd or 4wd, I'd just like to use this motor!
Old Oct 25, 2005 | 07:17 AM
wrkhrs6's Avatar
wrkhrs6
should drop in at LEAST 74-79. Steering column is diff from 74-77, so you will need to find another or go with whatever tranny is in the new body. If you have motor mounts, bell housing, etc, should go in dang near anything from about 67 - 86.
Old Oct 25, 2005 | 02:04 PM
312's Avatar
312
65 and up.
Old Oct 25, 2005 | 04:13 PM
Col Flashman's Avatar
Col Flashman
Earlier than that, as the 240c.i. I-6, the predessor of the 300c.i. I-6, came out in I believe '61.
So you can find an early '60s body style that had/has a 240 I-6 in it & go from there, if you wish to of course.
Old Oct 29, 2005 | 04:28 PM
wrkhrs6's Avatar
wrkhrs6
heh. meant to write 67-96, but could be 64 or so and up. Just depends on if you are happy with the in-body tranny. Personally, I like C-6's.
Old Oct 30, 2005 | 12:40 AM
GregTruck's Avatar
GregTruck
I guess at this point I will have to act as umpire here because there are a couple of very different answers to Strokin's question. Long story short 312 has both the shortest and most accurate answer. Anything 65 and up will accept the later model engine with no modification.
Also the 240/300 series engines were both introduced in 1965. No pre 65 truck will accept a 240 or 300 without major modification. Now someone can check me on all this but I feel like this is the story, and I'm stickin with it......
Old Oct 30, 2005 | 01:10 AM
fordflaresides's Avatar
fordflaresides
1965 was the first year for the 240/300, 1964 and earlier had the 223/262 six. The fuel injected 300 that came out in '86 have different heads. The early '80s might have a different cam shaft but other than swapping extarnal emission equipment the engine would still bolt in a early 80s truck.
Old Oct 31, 2005 | 12:22 AM
bigbrown84truck's Avatar
bigbrown84truck
correction... efi started for the 300 in 87.... The motor mounts change slightly from model to model from the sixties to the eighties so u may have to get different mounts, but that should be easy. you may also need to take the wiring harness from your donor truck since they used so many different ignition systems with the 300 over the years, thus if u get an 86 truck to drop your motor into the ignition won't just plug right in.
Old Oct 31, 2005 | 12:37 AM
Col Flashman
The '64-'65 engine mounts for the 240/300 were in the same placement area as the 223/262, which is a U shaped one on the front of the engine.
