Are thre better bulbs to put for your headlamps and fog lamps with out burning up the factory wiring harness. I thought someone had different lamp numbers on here earlyer this fall.
Not different numbers... 9007(headlights) and 9005 (fogs), most are replacing them with the Sylvania Silverstars, others with the GE Nighthawks. I replaced my headlight bulbs with the silverstars... what a difference. Do a search in the forum, there should be a bunch of hits
Silverstar (bright white, not blue) 9005 & 9007 on mine too, WORLD of difference for a low cost. Wally World has them for about 35 a pair.
Sometimes Summit Racing has a sale on them with the headlamp harness. I noticed a slight difference using the heavier harness ($40) from them with the 9007. In addition, the unused lamp socket allows you to put a ten cent diode in to operate hi and low beams without buying a $100 Brite Box.
Hey Steve, you got the SR kit right, do you remember if it is P/N SUM-890031? How do you like the quality of it? From kits I looked at in the past the going price was about twice this one.
Yes, the 890031, and it's on sale, 11 bucks off!
I like the harness, nice and clean. I removed the pax side battery and mounted the relay behing it and pulled the power from that battery. I slipped the harness under the gap cover between the radiator and tranny cooler. Got to get the diode in to have hi and low beams at the same time.
I need to re-read on the diode again. I want to wire that into an upfitter switch so I can toggle it. Know there was a thread on that, think I printed it off actually.
BTW, what is an "a/c mod" and "CCV mod" as in your sig?
I was just talking to my friend that also has a SD. In talking I realized this wires the headlights to the batts directly, with the dash just controling off/on via the relay. Does this cause any issues with battery life that anyone has noticed?
I'm thinking that you might be able to run a line from the auto-on relay that powers the lights to another relay that triggers the feed from the battery.
IF you can find it....
