Sponsored by: Kumho
Rear leaf spring question.
Old Oct 24, 2005 | 08:50 PM
48 F-2's Avatar
48 F-2
I have a 74 F-250 4x4, it has a broken top leaf on the rear. Can I swap a rear leaf spring from an F-250 2WD?
Old Oct 25, 2005 | 12:21 AM
rebocardo's Avatar
rebocardo
As long as they are the same width and length, yes.
Old Oct 25, 2005 | 06:07 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Your 4x4 most likely has 2.5" wide rear springs. Depending on the year of the 2wd, the springs may be 3" wide. I don't know about the 2wd because I've got a 73 that used to have 2.5" wide springs and I've had two 76 2wds that had 3" wide springs....so, thank Ford for being confusing. As for the spring length, they should be the same.
Cody
Old Oct 25, 2005 | 08:39 AM
seventyseven250's Avatar
seventyseven250
Check that centre bolt.
In addition to making sure the width and the eye-to-eye distances are the same, take a second to check the location of the centre bolt. It's not always in the exact centre of the spring like I would have imagined.
That'll save you the trouble of screwing around with leaves that "almost" fit, like I am.
Old Oct 25, 2005 | 07:55 PM
48 F-2's Avatar
48 F-2
Thanks guys. Yea the 2wd I was talking about is a 73, so I hope that would be a good match.
