Idle Very Rough
Old Oct 24, 2005 | 04:35 PM
who243's Avatar
who243
Idle Very Rough
I just bought a 1968 F-100 with a 390 and while it is idling, it is very rough and out the drivers side exhaust, it will pop but it's not consistent. It is idling at around 500 rpm's. It has been setting up for about 5 months and yesterday was the first time it has been driven since. Any suggestions on what the many problems I have. I have already sprayed the carb with carb cleaner and it has not made any difference yet. Any suggestions will be appreciated.
Old Oct 24, 2005 | 04:46 PM
1975Ford's Avatar
1975Ford
Welcome to the forum, For now recheck the engine firing order and recheck your timing.
Old Oct 24, 2005 | 06:42 PM
charles jones's Avatar
charles jones
Check your vacum lines as well I had one with a miss at idle and it was the power brake booster leaking
Old Oct 25, 2005 | 11:20 AM
fling's Avatar
fling
rebuild the carb, or buy a new one if its easier for you. They are right though, check your basics first (timing, vacume, plugs), most likly though your idle passages in the carb are gunked up causing half the 8 cylinders to be lean. How does it run when driving?
Old Oct 25, 2005 | 11:34 AM
bertha66's Avatar
bertha66
Idling at 500 rpms is a little low, I'd bring that up to about 700-800 rpms. Then check what the other posts a saying.
Old Oct 25, 2005 | 06:39 PM
BobbyFord's Avatar
BobbyFord
Definetly take a peek at the plugs, just to get an idea of whats firing.
Old Oct 28, 2005 | 09:10 PM
who243's Avatar
who243
I checked all the vacume lines and they are fine. I got it idling at about 600 rpms and it still backfires out both exhaust pipes but not like before.It also has a little black smoke from each exhaust so I'm sure the the carb needs some fine tuning.I have taken the carb off and am going to clean it out.The carb was just put on it before it was parked.As soon as I get some pics I will post them. Thanks for all the help.
Old Oct 28, 2005 | 09:18 PM
71 Sport Custom's Avatar
71 Sport Custom
It may be worth doing a compression check also. Get an idea of internal condition. Especially if the exhaust mainfolds are leaking at the heads. Good Luck
Old Oct 28, 2005 | 09:26 PM
ford390gashog's Avatar
ford390gashog
your timing and fuel ratio are way out of wack. time it to 12 btdc with vacuum advance unhooked. hook up a vacuum gauge and tune the carb.
Old Oct 28, 2005 | 09:36 PM
Fordzlla's Avatar
Fordzlla
I'd start with a full tune-up. Points, condensor, plugs, cap and rotor, timing, air filter, maybe even plug wires. After thats done and a few tanks of gas were through it , then I'd look at the carb.
Back in the '60's a tune up every 8-10,000 miles was the norm.
I just got my '70 out for the first time since May and it was running rough too.....turned out to be a loose spark plug wire.
Old Oct 28, 2005 | 09:44 PM
71 Sport Custom
Gashog, Where are you hooking the vacuum gauge, and what do you look for? thanks
Old Oct 29, 2005 | 07:26 PM
who243's Avatar
who243
I cleaned the carb this morning and put it back on and it runs great. I also checked the plugs,wires and put a timing light to it and set it to 12 btdc.Thanks for everyone's help.
Old Oct 31, 2005 | 09:59 AM
1975Ford's Avatar
1975Ford
Recheck the spark plugs and check if they are black and carboned. Replace if necessary.
