engine clicks on start-up
Old Oct 24, 2005 | 09:35 AM
hydrology_joe's Avatar
hydrology_joe
First, the good news...
I cleaned the throttle body & MAF this weekend and JEEZUS! I cannot believe the difference it made in the performance. Everything runs so much smoother and I have even noticed an increase in acceleration. I am NEVER going to ignore that cleaning again! Thanks to everyone for their insightful posts & comments!
Now, the bad news...
With the colder morning temperatures, I have begun noticing that my engine makes 4 rapid clicks on startup. (kinda of a tck-tck, tck, tck pattern with a slight pause after the second & third clicks) I am thinking this could be the oil drain down because of the filter. I am due for an oil change so I will see if that will help. I noticed the sound during the cold startups the past couple of years and didn't think twice about it until I read the posts here. What would be my next steps in fixing this if the new filter doesn't help? Thanks!
Old Oct 24, 2005 | 09:47 AM
J7Bones's Avatar
J7Bones
What process did you use to clean the throttle body?
Old Oct 24, 2005 | 10:21 AM
hydrology_joe
I followed the process as described on the discussion forums.
https://www.ford-trucks.com/forums/s...hreadid=127398
I used a teflon safe air intake / throttle body cleaner spray followed by a blow-out with compressed air. I only sprayed a little TB cleaner at a time and then dried it.
For clarification, the ticking noise has also happened in past years during cold startups... not just since I cleaned the TB.
Old Oct 24, 2005 | 08:11 PM
Ken00's Avatar
Ken00
I would do the oil change with the recommended oil/motorcraft filter and see what happens, if it continues put an oil pressure gauge on it an see if you have pressure when you start it up.
Old Oct 24, 2005 | 10:36 PM
seth1's Avatar
seth1
its probly a rocker knock my old 92 ranger 2.3 does it and so does my mom 99 taurus. is it worse if you let the vehicle sit a long time without starting it??
Old Oct 25, 2005 | 11:47 AM
hydrology_joe
Thanks Ken, I will get the oil changed this weekend. My time is already budgeted until then.
I don't know if the noise is "worse" if the truck sits a long time without starting, it is just more likely to occur. The noise is most common during morning startups in colder weather.
Old Nov 29, 2005 | 08:14 AM
hydrology_joe
The oil & filter has been changed with no improvement. I have found that if I let the truck sit for about 30 seconds with the key in the "On" position before starting it, the noise doesn't occur. I discovered this after getting into my truck one morning and trying to get organized before starting. I had the key in the on position while I was arranging my junk and when I started the truck... no clicking noise. I made sure and tested the scenario several times to be sure it wasn't a fluke and it really does alleviate the noise. Anyone have a clue what could be the cause? Leaving the key in the "On" position is just a patch, I would like to know what the problem is so it can be fixed. Thanks!
Old Nov 29, 2005 | 09:04 PM
Ken00's Avatar
Ken00
Thats a wierd one, are you sure it's coming from the engine. I would get some else to start it to make sure it's not coming from another location.
Old Nov 29, 2005 | 09:09 PM
RangerPilot's Avatar
RangerPilot
Very strange indeed, that just affects the fuel delivery. Get someone else to start the truck and use a screwdriver as a stethoscope and touch the various parts of the engine, both heads, front, accessories, etc, and see if you can pinpoint the noise. Caution the fan and moving parts. I know you don't have much time, but this will help.
