Speed density how does it work
Old Oct 24, 2005 | 07:37 AM
oldsw-31's Avatar
oldsw-31
What sensors are used for this system on a 89 351W? how does it work. my truck has no power and torque. the truck has new o2, coolant temp sensor, map, would the TPS or the MAT sensor cause this. The truck struggles up hills
Old Oct 24, 2005 | 08:54 AM
whiteyfordzx5's Avatar
whiteyfordzx5
this isn't vehicle-specific, but a quick search brought up this article:
http://www.carcraft.com/techarticles/24549/
seems to do a good job of explaining it so the common man can understand.
hope this helps!
Mike
Old Oct 24, 2005 | 09:47 PM
1990F2504604x4's Avatar
1990F2504604x4
Go here for some good answers. http://fordfuelinjection.com/?p=4
Old Oct 24, 2005 | 09:58 PM
pfogle's Avatar
pfogle
You need to pull the codes from the computer. See what it says is wrong, then correct it. The ford fuel injection.com link will give you good detailed instructions about how to do it. You will probably need a test light or volt meter to do it. In 1989 it won't be a Duraspark system, it'll be a TFI system. The TFI module on the distributor could be bad, or going bad. It could be a failing fuel pump.
Firefighter 1406
30
Jan 5, 2015 02:52 PM
tommybrede
Apr 7, 2010 09:28 PM
Sprint97
2004 - 2008 F150
Mar 21, 2008 09:03 AM
bcs
Nov 4, 2004 04:52 PM
