Pyro Install
Old Oct 23, 2005 | 11:53 PM
riley42204's Avatar
riley42204
Pyro Install
I was watching Trucks today and they took out the exhaust manifold to drill and tap for the pyro. Would you guys recommend that, or is it extra work. Thanks
Old Oct 24, 2005 | 04:21 AM
dvfd12's Avatar
dvfd12
That seems like a lot of work. I did mine on the truck. There is plenty of room to work if you do it from underneath. Just be careful and start with small bits. I even magnitized mine so all the shavings would stick to it. I haven't had any problems.
Old Oct 24, 2005 | 06:07 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i just drilled a hole, and then tapped it. the cast iron ruined my tap, but somehow still cut a clean thread pattern in. then i just vaccuumed the shavings out the best i could with a shop vac for about 30 seconds, then tightened the probe in. i have a pic in my gallery.
Old Oct 24, 2005 | 07:46 AM
1997F-350's Avatar
1997F-350
if you take it off plan on getting it resurfaced to line back up properly. dont waste your time and just drill it on the truck. those little metal flakes arent going to hurt anything.
Old Oct 24, 2005 | 12:48 PM
riley42204's Avatar
riley42204
Thanks for the help, that answers my question, I'll leave the manifold on the truck, now I just wish my gauges would get here lol.
Old Oct 24, 2005 | 02:37 PM
carwash's Avatar
carwash
My gauges finally came...i just dont have any time to put them in...ugh!
Old Oct 24, 2005 | 03:23 PM
PowerstrokeJunkie
dont try to squeeze the installation in. make sure you have more than enough time than what you think it will take. you dont want to get caught between a rock and a hard place.
